Question about HP OfficeJet J4580 All-In-One Laser Printer
My hp officejet j4580 all-in one is having problems feeding the paper. Paper feeds partially then jams.Repeated attempts resulted in same action.
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
Hp officejet j4580 paper jam message but no paper is jammed
you can disconnect the printer fron the power outlet and wait 5 min and reconnect.. if don`t resolve the problem you need to open the printer and find a smmal piece of paper jammed in the rolling. pls click if my solution was helpful and good luck
Dec 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Printer keeps on jamming
could be improper bond weight or thickness of paper, too much paper in the tray, or the wheels on the feed rail inside is broken or needs to be cleaned
Sep 25, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hi, my HP 4580 says there is a paper jam, but there doesn't seem to be one! Help???!!!
Sometimes the paper jam is caused by a tiny piece of paper. It can be smaller than a postage stamp, covering the paper sensor. Or it could just need cleaning. Look for very small piece of paper or look on edge of paper guide for small lamp sensor
Jun 12, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP officejet J4580 Printer
Rule # 1 never expose a paper feed device to "Tape" ....It will stick on the inside an cause a raft of problems....Look for a lever on the front/side of the printer and search for a method to open the top. Search everywhere for the license.
May 07, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP officejet 7310 - paper jam, but no paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Paper feed
Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
Dec 15, 2008 | HP OfficeJet Pro k550 Printer
HP OfficeJet 7310
showing paper jam and have checked and don't see any paper
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder is jammed and doesn't copy or fax
Is it jammeded or is it simply a warning saying it is?
Remove all paper and attempt a paper feed without paper.
The paper feed and delivery trays are removable so remove them and carefully reset them.
Making sure the paper is well fanned reload and retry.
Come back with the result.
Dec 13, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet J4580 All-In-One Laser Printer Logo
187 people viewed this question
Seeker5211
Seeker5211
