Question about Nokia 1110 Cellular Phone
When i get tone settings in nokia 1110 phone it is getting restarted. please help me how can i fix this issue?
  • 7 Answers
SOURCE: nokia 3120 restarts automatically.
reformat will work
Posted on Aug 21, 2008
  • 12 Answers
SOURCE: No ringing tone for nokia 1650
Any phone that turns off during performing a setting has a deffective software,if under warranty swapp it with your manifacturer, if out of warranty just purchase an other one from wallmart1
Posted on Sep 08, 2009
devdeep dhar
  • 375 Answers
SOURCE: i have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: My Nokia 1661 will not produce an audible ring
All phones have an option to reset to factory settings inside the menu somewhere, not sure if this will fix the problem?
Sometime different profiles are set funny like the ring volume being set low, maybe try a different profile?? hope this helps.
Posted on Oct 07, 2009
SOURCE: I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Posted on Mar 28, 2010
My Nokia 1110 is not ringing. I have reset volume, tone etc but still no luck. Would appreciate a solution. Thankyou
Hello,what you are Experiencing is a ear piece problem on your mobile phone.so all you need to do is to visit a mobile phone accessories store to get a new ear-piece accessories and visit a mobile phone engineer to help you fix it.
Take care.
Jun 15, 2011 | Nokia 1110 Cellular Phone
Tip
1200 ,1112 ,1110i ,1200 ,1208 ,1209 ,1600 ,1202 common problem
do you know that you can fix the common problem of nokia 1110 ,1110i ,1112 ,1600 ,1202 ,1200 and 1208 in your home and didnt lost your time and money by going to a cellphone repair shop or nokia care center...one of the caused of the said problem is the corrupted software of your phone..<br /> <br /> some of the problem that encountered by nokia phone 1110 ,1110i ,1112 <br /> ,1208 ,1200,1209 ,1202 etc .is not sending sms even you have signal and turn off when you go to tone settings if you want to change your message alert or call alert tone...<br />it is software problem but you can do it by youself by doing this...<br />1.MENU<br />2.SETTING<br />3.RESTORE FACTORY SETTING<br />4.ENTER LOCKED CODE (if not change it is 12345)<br />5.WAIT UNTIL PHONE IS REBOOT...<br /> <br /> after rebooting the phone ,test it and now you can used it in good working condition..but before you do the above action ,make sure that you save all the numbers in your sim directory becaused it will all deleted ..to save the contacts from phone to sim just do this..<br /> go to menu&gt;contacts&gt;copy &gt;select ,from phone to sim card &gt;all &gt;keep original and wait until its done ...<br /> i hope it will help you ,thanks for trusting fixya...<br />
on Feb 12, 2011 | Cell Phones
Tip
Do you know that you can fix nokia phone problem of not sending sms ?
1.MENU
2.SETTING
go to menu>contacts>copy >select ,from phone to sim card >all >keep original and wait until its done ...
on Jun 14, 2010 | Cell Phones
When i select ring tone my nokia 1650 mobile get switched off
hi,
i have a solution on that kind of trouble in my Tips here.............http://www.fixya.com/TipsAndTricks/posttipandtrick.aspx?thid=8247630
i open it for you:
do you know that you can fix the common problem of nokia 1650 ,1110 ,1110i ,1112 ,1600 ,1202 ,1200 and 1208 in your home and didnt lost your time and money by going to a cellphone repair shop or nokia care center...one of the caused of the said problem is the corrupted software of your phone..
1.MENU
2.SETTING
Apr 26, 2011 | Nokia 1650 Cell Phone
My nokia 1112i rh-93 gives a msg sending failed msg wheneva i try to send a text.how can i reset it
1.MENU
2.SETTING
Apr 20, 2011 | Nokia 1112 Cellular Phone
Nokia 1110i incoming call is not ringing
Your Phone Ringer Default So Please change Ringer And Problem will solved .
thanks.
Jul 20, 2010 | Nokia 1110 Cellular Phone
When i enter in nokia 1650 mobile tone setting its automatically restart problem please give the solution
hi,
your phone is having software problem ,it will fix by going to cellphone shop and reprogram it but you can also fix it in your home..
follow this ,
*MENU
*SETTINGS
*RESTORE FACTORY SETTINGS
*ENTER YOUR LOCK CODE
test it now,go to tone setting and select the tones you want and its done...i hope it will help you ..thanks for trusting fixya
Jun 20, 2010 | Nokia 1650 Cell Phone
Mar 23, 2010 | Nokia 1661 Cell Phone
Composing of new Ringtones
you can get new ring tones via sms or you can compose it by yourself
first press menu,goto extrasin thatpress composer in that you can edit the tones which you already had or you can press by yourself
Sep 13, 2008 | Nokia 1110 Cellular Phone
Nokia 1110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
