Bulova Watch Logo
Posted on May 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set time and date using crown movements for vacheron constantine  malte dual time regulator wrist watch
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on May 06, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291921
Points
7081
I have examined their web site and they do not have any online instructions.
I suggest that you go to http://www.vacheron-constantin.com/en2/contact/ and find your nearest retailer and discuss your problem with them.
2answers
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
Cant set wrist watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
DATE WONT CHANGE
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at: [email protected]
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
0512037FA Wrist Watch: how do you set the date in the window of a seiko 6...
mcdevito75 here, The stem should have 2 positions to set the DATE without haveing to cycle the watch 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it's first position, it may take practice so be patient, once in it"s first position you can easily change the DATE, change it to 1 DATE before the DATE you want. NOW! push the stem back in and then pull it out to set the proper DATE and time of day, your watch is set and will change on time, around Mid Nite.
17helpful
2answers
How to change the date and week?
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
11helpful
Setting the time and date
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
2answers
Breitling navitimer watch
breitling navitimer, keeps perfect time on the desk, but when ion the wrist it runs fast, as much as one hour in 24 hrs
9helpful
How to change the date on cartier santos chronograph watch
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
