Question about Garden
Replacing cones on a Dixon ZTR mower
Need instructions on replacing cones on a Dixon 4422 ZTR mower
5 Suggested Answers
  • 4 Answers
SOURCE: I have an old Dixon ZTR 308 that I need help with.
check to make sure that your blade engaged switch is working properly.
Posted on Sep 26, 2009
  • 61 Answers
SOURCE: where on the Dixon ztr 5421 do you check the
there should be a sight glass or a dip stick in the
hydraulic tank.
Posted on Sep 06, 2009
  • 61 Answers
SOURCE: i have a 1996 721d
ck belt and tension pulley.
Posted on Sep 07, 2009
Dolfoff
  • 148 Answers
SOURCE: Dixon ztr 311 The left lever will not make the
The motion drive design is similar to a set of spider gears, except it uses friction material rather than bevel gears in the cluster. The friction material may be worn down to the point that it no longer engages and needs replacement. This is a likely scenario for the symptoms you describe.
The replacement procedure is a rather involved process. If you feel confident and are VERY handy, reply to this post and I'll be happy to go into detail.
Hope this helps!
Posted on Oct 01, 2009
Testimonial: "Thanks, lots of help. Details would be great"
On my 2003 Dixion ztr 3303 then I push both handles forward equally the mower goes off to the right. Also it is like the right wheel has more power than the left wheel, any idea on how to fix it.
The drive unit needs to be adjusted. This unit uses the "Cone Style" drive system. These are extremely difficult to adjust or repair. If you have a Dixon dealer in your area, I recommend him doing the adjustment.
Nov 27, 2017 | Garden
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Need a belt diagram for a dixon ztr 5023
Dixon 5000 Series Belt Diagram
Jul 21, 2014 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
How to remove small sprocket and chain on a Dixon ZTR 4422
Try using a open end wrench, there is a chance that the rod will slide the other way when you undo the nut which will allow the nut to come off and not his the carriage.
You can check by loosening the nut about enough to get a pry bar in then see if you can push the nut back to the gear, it it moves that means you can get it off.
Apr 14, 2013 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Garden Logo
1,002 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
