Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
Jeep comanche radio wiring
Hi ! I just bought a 1988 comanche and there was no radio in it so i bought a new one but i dont have the radio wiring diagram ...i tried to find it with no success! can someone help me plz! thank you!
  • Anonymous Jul 25, 2008
    The ST light comes on put no numbers and no sound
    Can you help!!!
    I've been Unpluging and repluging
  • Jinxxyboy Aug 20, 2008
    I also bought a comanchee X. its a 1986, i was told that it had an infinity sound system in it. I need to know the wirning schematics so i can cut the plugs and hard wire the radio directly into the vehicle. My jeep is equiped with to plugs. One i assume is the speakers, and the other is for the juice and ground. can you e-mail me the recipe, or fax it to (989)846-9200 it would be greatly appreciated! [email protected]
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
This is a generic install direction. Try this
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Mar 26, 2008
SOURCE:
My turn signals on my 1988 Jeep Comanche dont work.
My first guess would have been the turn signal switch, which you said you replaced.
You'll have to get a wiring diagram of the switch and start testing wires for power out of the switch. Could be a problem with the main harness going back to the rear of the truck, or a ground for those sockets.
Oct 12, 2012 | 1988 Jeep Comanche
Need radio wiring diagram for 1988 jeep comanche
  • Constant 12V+ Pink
  • Switched 12V+ Purple/Orange
  • Ground - Black
  • Illumination - Orange/Black
  • Dimmer - Dark Blue/White
  • Antenna Trigger - Gray
  • Front Speakers - 5 1/4" Doors
  • Left Front (+) - Green
  • Left Front (-) - Black/Yellow
  • Right Front (+) - White
  • Right Front (-) - Black
  • Rear Speakers - 5 1/4" Tail Gate
  • Left Rear (+) - Gray/White
  • Left Rear (-) - Brown/White
  • Right Rear (+) - White/Black
  • Right Rear (-) - Brown
Oct 27, 2011 | 1988 Jeep Comanche
I have an 88 jeep comanche that has a new battery and new alternator but wont keep charge. What could be the problem and how do I fix this.
IF YOU CHECK FUSE.BATTERY CABLES COULD BE FAULTY IF VERY OLD.THEY CAUSE HIGH RESISTANCE IN CHARGING CIRCUIT.CHECK FOR LOOSE DRIVE BELT.AND CHECK ALTERNATOR WIRING IF BROKEN OR DAMAGE YOU WONT GET CHARGED.AND MOST OF ALL MAKE SURE YOU BOUGHT THE RIGHT AMP ALTERNATOR.
Sep 17, 2010 | 1988 Jeep Comanche
1988 Jeep Comanche transmission will not shift automatically
chapters and indago sell chilton books they are a god send the have all the wiring diagrams in the back of the book also auto zone carries the books too
Jan 13, 2010 | 1988 Jeep Comanche
I need help with a wiring diagram for my 92 Jeep
Review this post, Wiring harnesses & adaptors
Good luck (remember rated this help).
Sep 28, 2009 | 1988 Jeep Comanche
Need wiring diagram for 1988 jeep comanche 4x4 6
check the solenoid on the starter it powers the ign for starting then switches to run when you let off key,either the solenoid is bad or a wire to the solenoid has come unhooked and sometime they have an in line fuse which can blow.
Sep 26, 2009 | 1988 Jeep Cherokee
Need diagram of vacuum system for 1988 jeep comanche pick-up 6 cy
Haynes manual has a diagram. Main important hookups are to power brake booster, fuel pressure regulator and map sensor. also need a connection to a/c controls inside drivers compartment and evap system canister. will also need connection to egr valve solenoid if you have one. as well as pcv on valve cover (or ccv which replaces pcv on some)
Mar 03, 2009 | 1988 Jeep Comanche
Car Audio & Video Logo
845 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Larry Tezekjian
Larry Tezekjian
Tom Chichester
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
