HP C4380 printer won't print wirelessly
The printer installs ok and works on first installing. However once the computer and router have been switched off (and obviously on again) it stops working and says printer disconnected - any ideas would be great
  • 5 more comments
  • Bert36 Mar 27, 2008
    all i did was turn everything off as if i was going to bed and when i turned it back on it says printer disconnected and pc wont print.
  • perryconrad Mar 29, 2008
    Same problem. i have reinstaleld software and it starts working for a while, then goes offline again and I cannot do anything to get it back.
  • Bert36 Mar 29, 2008
    I think it must be a problem with the router or firewall because i re-installed and all was fine again,turned off pc and printer and it worked when i turned both back on,when i turned off the router the printer stayed disconnected.please help.
  • Anonymous Jun 28, 2008
    the printer stays offline and will not go oline!
  • tailhook Jul 28, 2008
    The c 4380 is good to fill the mental instutions with ist users. After initial installation on two of my computers (Vista) it worked ok although not as advertised during the installation directly to wireless. It took some hassling to get it working. But after trying to install a third, XP driven computer, things started to go wrong. I got the XP and one Vista driven connected thru USB cable ok but the wireless function simply won't work. The testreport says everything works fine, don't you believe it. During the umph reinstallation aInoticed that although HP tells you that the printer is installed, Vista has a completely different idea about this and seperate installation via vista is necessary. In all, I asked HP to take the thing from the market because the mental institutions are already fully booked. HP is simply not reacting to complaints. good luck. Tailhook
  • pests13 Aug 07, 2008
    my c4380 has similer problem I get as far as message connected wirelessly to my bt router but as soon as i pull the usb lead i get the printer disconnected message, printer prints perfecly when usb plugged in ?
  • jeremy197jer Oct 23, 2008
    the HP Photosmart C4380 series is the worst printer our business has ever bought because it hardly ever prints wirelessly without problems. We bought two new printers at two locations - the first won't print wirelessly to a new Vista laptop, the other will print when first installed but always drops out of wireless print soon afterwards. We've tried the solutions on here, no joy long term. It's so frustrating that - 5 weeks after buying them - we're throwing them away and going back to the Lexmark wireless printers we had before. We will never buy any HP printer again.
  • 3 Answers
I was having the exact same issue for months and only now I have been able to resolve. You are correct. It is the firewall causing the problem. Your computer will send out a "keep alive" message out to the printer. I use AVG firewall and by default it blocks the UDP packet. Since the packet is blocked, Windows thinks the printer is "Disconnected."
In AVG, I changed the program C:\Windows\System32\svchost.exe from Block to Ask. Almost immediately the system asked to allow the packet. I did allow and now the problem is resolved. You only have to allow one time. I'm sure Windows firewall is similar.
Posted on Apr 21, 2008
I experienced this problem and found that my AVG firewall was blocking communication from my PC to my wireless printer. I found the AVG Firewall setting for an application called "Various System Services"(This controls the file C:\WINDOWS\system32\svchost.exe). From this "Application" it was a matter of adding an "Application Rule" specifying UDP Port 427 Inbound and Outbound, and setting this rule to "allow for all." Hit OK. Voila, printer works great!
Posted on Nov 06, 2009
If you are using AVG 9 and Vista and cannot scan using the HP Solution Center to access the scanner. The problem WILL be with the svchost.exe RULE assigned to the profile that you are using according to AVG. Edit this rule (find the first UDP "subrule") and add UDP port 427 to the remote ports "OK" list. You will probably already have 0-65K "OK" on the local list. And, make sure that acess is both ways. I have spent a lot of time dicking around with this one....
Posted on Oct 29, 2009
    Problem Solver:
  • 13 Answers
Wait4me put me on track to my solution....
My AVG already had a rule to always allow svchost.exe... but the printer was still not detected. I DELETED THE RULE.
Scanned for the printer again, and when the firewall detected the traffic from svchost.exe I chose ALLOW as a permanent rule. My problems are now solved. I don't know what was wrong with the original rule, it looks identical, but delete/recreate fixed my issues.
Posted on Oct 16, 2009
I have NO solution to my problem with this HP printer, HP will not help until I will buy extended warranty,and I just installed this printer two days ago, it doesn't work wirelessly or automaticlly, every time I can use it I have to hit the power bottun of and on to work and the USB wire should be connected to the pc. I am having amazing problems and I cant resolve it period.. And HP doesn't care to help us in any ways..Just they want money and resolving the problem is not guaranteed... RUBY
Posted on Aug 14, 2009
  • 3 Answers
I wasn't having issues with the security at all, I am using mac os. I just can't let the two device meet halfway through..my computer is connected to the network and the printer as well as it generated a valid ip address. When I tried to install it, it is having issues that it can't find the printer on the network. I tried to reset the printer and connected back to the network and now the installation found it. I want to share with you the steps I did to reset it, here's the link How to Reset the HP PhotoSmart C4400 through the Secret Combo Keys. goodluck guys. my hp c4300 is just amazing.
Posted on Aug 17, 2012
My solution: Setup the network on the printer to pass by using the USB connection. Install Apple's ZeroConf / Bonjour / Rendevous / mDNS (yes, it's really called any of those) for Windows from http://developer.apple.com/networking/bonjour/download/ then use the "add printer" utility to scan for the local name of your printer; it's like HP00AB02.local. (usefull huh). When prompted for the driver for this printer, select it from the CD's *.inf files. Now you have a NAMED ADDRESS, which unlike the IP address won't change when you turn your router or printer on and off.
Auxillary Sollution: Firewalls ****. Uninstall them. Your router should be doing that job. If you travel with your pc (it's a laptop?) and connect to strange networks in the night or you invite people who may have been connecting to strange networks in the night to use your network instead of a guest wifi router, use only the Windows Firewall, because at least it won't disable all the windows file and printer sharing stuff.
Posted on May 12, 2009
You need to reserve an IP address so that each time the printer turns on it is given the same IP address by the router, otherwise the drivers have trouble finding it (badly written drivers)
Log in to your router and look for a setting for reserving IP's. It will be specific to the router so I cant really be any more specific.
I hate this printer, I have had so many issues due to problems with te vista drivers, total waste of money and my time. I still cant always get the scanner to work wirelessly and every 40 minutes the scan head moves on its own. So I have to have it turned off other than when I am using it. Not much point in wireless if I have to go to it and press the button each time I want to use it and then again when I am done.
Posted on Jan 13, 2009
Windows XP solution:
Ok, so the only reason i knew how to do this was because i used to dabble in some IT. Once you have the network printer test set to PASS you are only half done. Next you need to put the Driver's CD in and find the IP address (should be on your PASS test piece) from the printer on your network. In my case it was 192.168.1.101. I then went to "add a printer" to my computer. Pick Local Printer, uncheck "Automatically detect for....." and hit next. At the next screen, Highlight the "Create New Port" option. In the dropdown select "Standard TCP/IP port". Click, Next, then Next again. Enter the IP address from your printer (in my case 192.168.1.101) and the port will figure itself out. Click Next. It will take a second to find the IP address, and then, it will ask you for drivers for this device. Point it towards the CD-rom where you should have the Driver's Disc in. The rest is pretty simple. Hope it works!
Posted on May 29, 2008
Yup, I had exactly the same issue too. I also manually set up the port for the printer to the IP address, which made it print wirelessly, even though the printer monitoring software, and HP solution Centre thought the printer was still "disconnected". But, I found that even though I could now print, I couldn't scan - the printer gave a warning "USB or wifi network not connected".
After a phone call to HP, they got me running the install CD, choosing option "Add device", then "Using Network" (wifi), where I chose the printer. This set up a second copy of the printer, which had it's port pointing at the same IP address but where the port name also included the device serial number. So, this seemed a more proper way to set up the IP address. I could still print wirelessly, but still could not scan.
I turned the printer off and on, just to see if it needed to pick up the network that way. Unfortnuately, when it came back on, though I could still print wirelessly, HP Solution Centre could now no longer see the printer, saying "Disconnected".
I gave up at this point and am about to take the printer back to where I bought it.
Andrew
Posted on Oct 24, 2008
    Scholar:
  • 141 Answers
Did you turn your printer "OFF" and "ON", reboot your PC to.
Posted on Mar 26, 2008
  • Patrick St-Jean
    Patrick St-Jean Mar 27, 2008
    De-install your printer of your computer and re-install it...
    Make sure you install the cd(driver) before connecting your USB cable to your printer....Sometime it happens!
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
Printing wirelessly from my macbook
Can you check to be sure there is a relationship between the laptop, printer and access point? All on the same SSID?
Jul 06, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Wireless connection issues
First open services goto start Run type services.msc and see for the entries (hp cue discovery , hpqcxs08 and hp network device) and make sure they are enabled.
Then Goto device manager (Right click on computer and then properties then device manager) Here click on View and show hiden devices and under network adaptors see if you have a red X on HP Printers then delete all he etries you have for HP here (If t prompters a restart restart later) after you have deleted all you may restart your computer.
Then start to install or add a device from the disk.
If it finds the printer do not click on next got to device manager then view and show hiden devices and see if you have the HP Printer with a Red X if yes right click on it and enable it (If it prompts a restart DO NOT RESTART) close this device manager window and in the instalation widow click on next and it should complete the installation.
Good Luck
Dec 06, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP C4380, Wireless Printing Problem
Do you have other printer drivers installed, if so thre may be a driver conflict. wireless printing requires network connection and also printer drivers. This appears to be a driver issue since the printer shows up on the network. I would try reinstalling the drivers.
Aug 27, 2008 | Office Equipment & Supplies
Blurred printing
You should be able to re align the printheads using the software package on the computer which you installed whenn you installed the printer
Jul 22, 2008 | HP Office Equipment & Supplies
HP Photosmart C4380 All-in-One printer
check the ports first.. make sure that the printer is set as default ( make sure it has the green tick and the status "ready" or "online" on the printer icon in the printers&faxes. and if u want to connect it wirelessly, you have to install it as usb first before changing to wireless........
Jun 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Trying to instal photosmart C4380 all in one wirelessly on toshiba L40-17M from supplied disc installed printer ok first time but scanner not recognised, scan button says computer connected but computer...
Photosmart C4380: good hardware, appalling software. Shameful that it's on the market at all.
WIRELESS PROBLEM
You have to install the printer as USB first. Then, once it's all installed, load up the CD again and 'Add device', choosing the wireless option. It's crucial that you leave your USB cable in the whole time. Take it out right at the end. Once you've added a device, you'll have two printers installed. One will be called 'Copy 1' - that's the wireless one. It should all work okay, and you can delete the USB one.
SCAN PROBLEM AND ERROR MESSAGES
When I did this everything seemed to work fine. BUT - after a wee while the software started playing up. The scan function didn't work at all, HP was depositing all sorts of bugs all over my computer, I had error messages coming up at shutdown, all sorts of gremlins.
So this is what I did.
I totally uninstalled all HP software.
I downloaded the updated Photosmart Basic Drivers from the HP website. They are here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3221646&lc=en&cc=us&dlc=en&submit.y=11&submit.x=9&lang=en&cc=us
Once you've downloaded the file and run it, the new drivers will be installed but NO SOFTWARE. Again, you have to do the whole setting it up as USB and then leaving the cable in and adding the device wirelessly. But if you do this with the HP drivers and ignore the installation CD, then everything should work perfectly.
Of course this means no HP software at all. But who needs it? I use Microsoft's scanning software, which is fine, and it has no problem printing.
Basically HP's software is BLOATWARE that doesn't even work. It screws up your computer.
Good luck!!
Apr 21, 2008 | Office Equipment & Supplies
Is the blue light on the wireless button on the side of the printer lit up?
Mar 31, 2008 | HP Photosmart C4180 All-In-One InkJet...
Unable to complete wireless installation of HP Photosmart C4380 All-in-One
I had the same problem where I could get the HP Printer to access the router due to MAC filtering. I tried hard to find the MAC Address of the printer but was unsuccessful as it was not printed anywhere on the box or printer. But this link really helped me:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01123173&cc=us&lc=en&dlc=en&product=3221646&dlc=en&lang=en
I printed it out and it had the MAC address on it... Configured my router and it's now working great... Hope this solves your problems
Oct 31, 2007 | Xerox DocuColor 12 Printer
11,127 people viewed this question
k24674
jasbo
jasbo
