Question about Toshiba Satellite A135-S2276 Notebook
Can't get the password from bios
After it has been restarted, there password appears before we log in to the user account...
Umm..printer ports are long gone. Your device is outdated by about 10 years.
Posted on Nov 07, 2012
  • b_barrett6
    b_barrett6 Nov 07, 2012
  • Toshiba Master
  • 12,061 Answers
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Posted on May 06, 2010
My computer is asking for a start up password is this a virus How do I Get rid off it
you cant get into ur pc unless you have the password, am i right? if so, restart the pc and keep tapping the delete button on pc/laptop, then start as administrator when you get in goto control panel look for account wen u got it delete the old follder and make a NEW one, just follow wot it tells u, if still no joy try get a hold of me, paul.
May 31, 2015 | Microsoft Windows XP Home Edition
I forget password bios for acer 5230
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
If all else fails you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard
Many RTC's require an external battery. If your RTC is one of this type you can clear the BIOS password just by unsocketing the RTC and reseating it
click start type cmd press enter.
-Type control userpasswords2 then press enter
- With the User Accounts window open click on the Users tab.
- Clear the box that reads "Users must enter a user name and password to use this computer." and click Apply.
- A window will appear asking you to enter the name and password for the account you want to automatically log into.
- Once you have entered that information click OK to close out of that window and again click OK to close out of the User Accounts window.
this will vary depending on your operating system
Hope it helps
Jun 02, 2012 | Acer EXTENSA 5230E COMPATIBLE LAPTOP LCD...
I brought a dell gx280 but I don't no the admin password can get. It and change it?
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
hope this helps you
start a windows xp system up n safe mode then click on control panel ten user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one.
Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys
then press the ENTER key. Choose "Windows XP Home/Professional" depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK
Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
hope this helps you
start a windows xp system up n safe mode then click on control panel then user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one.
hope this helps
May 15, 2012 | Famous Brand Dell Optiplex GX280 Intel...
Lost password on hard drive
hope this helps you
Mar 26, 2012 | Computers & Internet
Clear cmos
if you want to reset your password or your cmos
also
hope this helps you
start a windows xp system up n safe mode then click on control panel ten user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one. Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
hope this helps you
Sep 29, 2011 | Intel D946GZTS Motherboard
I need to reset my password on my Dell Studio 1535.I forgot what it was and cannot start up without
also
hope this helps you
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.:
Close the User Accounts window and restart Windows.:
hope this helps you:
Sep 26, 2011 | Intel D865GLCLK Motherboard
I have a Dell latitude e4310 laptop my 10 year old has somehow changed the password and locked my computer. Can you please help
If you haven't set a password for the Administrator account you could try to log in as an Administrator then change your password back. First you need to change how users log on.
1. Click Start
2. Click Settings
3. Click Control Panel
4. Click User Accounts
5. Click Change the way users log on or off
6. Deselect Use the Welcome screen
7. Click Apply options
Exit Control Panel. Then Restart computer, hold F8 when rebooting and choose SafeMode when prompted.
When Log on Prompt appears type in Administrator as user and leave password blank ( this is the Windows default password)
This will let you boot into Windows where you can go back to Control Panel, User Accounts and change your account password.
Then just reboot normally and enter new password.
Hope this helps. Thanks for using FixYa.
Sep 17, 2011 | Computers & Internet
I forgotten my password
Restart the computer and during bootup hold down F8, in the next menu select safe mode startup. Once the windows login selection appears select administrator. Hopefully, there is no password prompt, if there is enter the adminstrator password if you know it. Once logged in the admin account, go to control panel, user accounts and select the lost password account and select change password. Restart the computer and and log into your account using the password that you changed.
Sep 13, 2009 | Handmark Software MobileLists (950142) for...
Forgot password......windows xp compaq s6000cl not a notebook
if you forgot your password restart in bios then advanced or security and user passwords you can change
bios administrator password i am not sure if you can change or remove if you forgot it
you can also restart in safemode and follow instructions i gave you earlier
let me know
Feb 18, 2009 | Compaq Presario S6000CL (DT072A) PC...
I forgot my Administrator Password
Here's How To Recover the Password
It's a little bit tricky, but it work's my dear..
SULOTION/S:
The problem here is the Setup program did not complete properly. During the Setup operation, Windows assigns temporary passwords to each user account; these passwords are stored in a file called setupact.log in your Windows installation folder. When the Setup program completes properly, these temporary passwords are cleared, allowing you to set up your own password. But if the Setup program does not complete properly, the passwords are retained.
To resolve this problem, find the setupact.log file and locate an entry that reads
“Random password for Username is [password].”
Write down the password exactly as it’s written and use it to log on to the account. How you do this depends on whether you configured your file system as FAT32 or NTFS.
If the file system is FAT32, restart your system using a WinMe or Win98 startup disk. At the command prompt, type edit c:\windows\setupact.log and follow the instructions above to locate the password.
If the file system is NTFS, configure your BIOS settings so the computer boots from the CD drive and insert your WinXP installation CD into your CD-ROM drive. Restart the computer, and at the prompt press any key to boot from the CD. Press r at the Welcome To Setup screen to launch the Recovery Console and then press ENTER when prompted for the administrator password. At the command prompt, input type setupact.log and press ENTER. Make a note of the password associated with each account. Restart the computer and use the retrieved password to log on to the user account.
Cheers!
-micromaster
Mar 09, 2008 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite A135-S2276 Notebook Logo
404 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
