Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
I have a 2hp b&s motor that isn't getting spark.I had it sitting under a tarp for a while then my g/f moved it out into the rain. its an older motor off an edger. i got a new spark plug and it didn't help. If i hold the metal on the wire it will shock me but it doesn't send any shock through the plug. i went to clean the magneto and a black wire snapped inside where the plug wire comes out. also the only way ive known to kill the motor is grounding it with metal like a screwdriver etc. could there be a black wire somewhere that is disconnected or do i have bad points? any help is appreciated
  • 12,061 Answers
Ok, change your spark plug lead and plug.If you get a "Shock" that sorta proves that it is all OK, check, ALL wiring, ends on wires, and connections are all clean and shinny. Clean with fine emery or sandpaper, That Black, wire is probably the "Kill" switch, it shorts out the Coil, to earth, and stops the motor. make sure that it's NOT touching earth.
Posted on May 06, 2010
Testimonial: "alright will do. i have cleaned the fly wheel and the mag already. The wire comes to the coil from the botom of the motor and it broke off with very little wire exposed on the coil. do i need to sadder it back or is there somewhere else i can connect it. Thanks for your help."
Where should I look for rain water leak?
Most water leaks come from around the windshield area. Has the windshield been replaces recently? If so it may not be sealed properly. Another area where water may penetrate is through the cowling area under the wiper blades/arm where fresh air enters the car. There are water drains under this cowling allowing water to drain and if they are plugged with leaves/debris, water will enter the vehicle. Is the vehicle rusted around the windshield area? If so, suspect this to be the source of water intrusion. Most glass/windshield repair companies will diagnose water intrusion problems
Oct 10, 2015 | 2003 Hyundai Accent
2005 Chevy Silverado, 4.3 liter, 2wd. It won't start
could be moisture is that year a coil pack or distributer
Dec 04, 2012 | 2005 Chevrolet Silverado
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
Car skips when started
spark plug wires may be bad. when have you changed spark plugs? look under hood when it's dark to see if there are 'sparks' coming off wires.
Aug 05, 2012 | 2002 Buick Rendezvous
What's a footprint tarp?
It is a tarp that fits exactly under the footprint of your tent, but is an inch or two smaller. If you have a 10' x 10' tent, your tarp would be about 9'10" x 9'10". If you have a triangle-shaped tent, your tarp would be triangle-shaped.
It is smaller than the tent so rain (etc) does not dribble down the tent wall, land on the tarp, and pool under the tent.
Jul 30, 2012 | Camping, Backpacking & Hiking
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
2005 Taurus get water on driver side after hard rain.
the water is draining from the windsheild area there is a drain and that drain has become blocked with dirt or leaves etc
Feb 24, 2010 | 2005 Ford Taurus
Kohler 15 hp electric start seized up
Sounds good to me. Must of got wet in the rain?Who knows. Marvel works good. You can even put a little in with your oil change. Try to breck it loose by hand if you can.
Nov 06, 2009 | Garden
Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Apr 10, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
731 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
Dan Webster
Dan Webster
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
