Question about JVC AV-65WP74 Rear Projection Television
Blue lines .
I got some some blue lines crossing along the middle of the screen , i opened up in the back and using a mirror i saw the problem is inside the blue lens .is a digital delta 260 .
i called some place the part costo U$ 600 . i wanna be sure that is that the problem and not something else .. some help ,write me to :
bywed22000@yahoo.com
  • bywed Mar 27, 2008
    well i alreday order the part , now you can tell me in easy way how to install it. step by step ,i can of nervous because i only know how to turn it on and off .but i'll dare to do isntall it with some help .
    where this thing goes ? i opened and i saw three lamps ,the blue one is the one that is bad , is it close to this lamp where this chip goes ? ....
  • JVC Master
  • 19,396 Answers
Usually you fix the convergence problem on AV-65WP74 replacing the STK392-110s, then do an convergence realign setup. You need to desolder and take the chips out and put a new pair in and soldered them back. their cost vary fron $7 to $40. Labour may be expensive.
Regards
Posted on Mar 26, 2008
  • Ginko
    Ginko Mar 27, 2008
    Well, replacing convergenge ICs on your tv board involve unsoldering them and precision soldering them back on the board without blowing the rest of the tv. It is not a difficult task if you have esperience with this kind of works. If you have scarce or no experience in servicing electronics you may risk to cause further damage. You will need to replace one, or both circuits indicated as IC804 and IC805.Start from IC804 and see if it works, then eventually repace IC805.
    Both ICs should be replaced with STK392-110 or STK392-150, last one offers more resistance to heat.
    You will need service manual or schematics to do the job.
    If you sign up in this forum they will send you service manual for free.
    This one here instead will sell
    AV65WP74/HA Service Manual for $15.
    Leave your tv set unplugged from power for a while before servicing it and ensure you are using right tools and equipment.
  • 4,889 Answers
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. I think what your are assuming as lens is the blue lamp that has gone bad..
  • 796 Answers
The convergence IC's are failing to perform properly...
you might need to replace them
How to remove door mirror cover from 2009 ford focus
There are 7 tabs holding the mirror cover on three along the bottom ,two just below the horizontal middle line and two at the top.Squeezing the bottom corner near the car towards the outside of the mirror and pulling gently forward will release the weakest clip at the bottom.The other two bottom ones poke vertically down, the middle two hook over their slot with the hook facing down.Lifting the bottom edge of the mirror cover will help release these. As in the manual push the mirror back along the bottom edge to get some access at the top then using a thin screwdriver push down on two black clips at the left and right upper side edges of the top of the mirror try at the same time to lift the mirror cover up and towards the back of the car to release the remaining bottom and middle clips.Have a look at night with a torch and you may be able to see what is going on with the top two clips. Be careful not to apply too much pressure and break the clips.
I have taken pictures which I will try to post on another site.
Most mechanics were useless in explaining how to do this but I finally found one who could.
The other answers above are not relevant.
Jun 10, 2012 | Ford Focus Cars & Trucks
Blueish hue throughout picture, like a blue ghost a couple of inches to the right of objects on the screen
Your TV's Convergence may be out of line. To adjust this do the following.
1) Press the Menu button on your TV/Remote
2) Scroll through and select the "Advanced Features" Menu.
3) Select Blue Convergence
4) Use the V keys on your remote till the cross hairs are all lined up in the middle of the screen and the center one is white.
4a) You can use the "Video" button to switch between the red & blue cross hairs.
Dec 28, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Suddenly there are blue horizontal linings all over my screen..even when i start video these linings are acroos them???
Sounds like your screen is going bad, specifically the connectors along the edges.
Try this: grab the top edge of the screen by the sides, put your thumbs on the plastic at the top and as far towards the middle of the screen as your thumbe will reach. Use your thumbs to push the middle of the screen back from the edges of the screen just a little bit.
BE GENTLE, you should only need about twice the pressure you'd use to press your spacebar on your keyboard.
If one or more of the lines disappears, the screen is going.In some cases, you can get rid of most of the lines by doing this, but they will come back the next time the laptop gets a good bump.
Aug 29, 2010 | Computers & Internet
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
RCA 52 HDTV working fine when suddenly a band of color, red, blue and green appeared at top of screen. Picture curved inward from top and bottom. Picture is blurry and has double images. Television is less...
There could be a convergence problem. Try these:
  1. Press MENU then choose SETUP>AUTO CONVERGENCE.
  2. When Auto Convergence is complete, the Red center convergence menu appears. The cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to move the red cross to overlap the green cross. Press OK when adjustment is complete.
  3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK.
Sep 25, 2009 | RCA HD52W59 HDTV Projection Television
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Hitachi 50 inch projection tv
Convergence ICs replace them bot 2 big black ics STK392-560s not sure what your STK numbers are but use same number to order parts call Electronix Parts 1-800-223-3205 PS if they are using 110s use 180s if 020s use 040s better ics.
Dec 19, 2008 | Hitachi 46F500 46" Rear Projection...
Convergence 3D
You have to try auto convergance from the menu.
There ust be convergance adjustment on menu.You will find cross at center of the screen.green cross is the refrance ,you have to overlap red and blue to form white cross.
once you have formed white cross than the picture will be perfect.
Jan 09, 2008 | Zenith R56W36 56" Rear Projection...
Another Convergence Problem?
dont move the pic tubes that will be a costly mistake the problem is still your ics replace them all you should have two check for bad solder connections
Nov 12, 2006 | Toshiba 50HX70 50" Rear Projection...
Convergence
If the CRT Projection television has several colors or one that arent lining up, if due to an impact - you may have a broken mirror, if just happened all by itsself it may be a convergence issue, either issue is repairable, probably for around $400-$500. I dont recommend taking a set like that into the shop as sometimes transport can break/crack a mirror or throw convergence off.
Sep 30, 2006 | Panasonic PT-47WX42 47" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
