Question about HP OfficeJet 6110 All-In-One InkJet Printer
Set up scanner on computer. How do you do it??
How do you set up your computer to use the scanner?
  • HP Master
  • 12,061 Answers
Http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=us&product=79477
Ok, go to above website, download and install, all software you need, the printer, scanner and Scan manager too. Also download and read the manual, it shows you step by step how to do it.
Posted on May 06, 2010
I have a Cipherlab scanner 8001, when i connect it to a linux computer, it doesnt download it gives me a Time out error, but when i connect a Cipher scanner 711 to the same COM port it works. Please advice...
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
Jan 30, 2011 | CIPHERLAB 8000 Series Handheld Mobile...
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
Jan 05, 2010 | Xerox Phaser 6110 Laser Printer
Not connecting with computer
hello, not enough information given to diagnose your problem correctly, but sounds like you may have left out a step, when hooking up the scanner, some require the software and drivers to be installed before you hook the scanner up to the computer, aka you install the scanners software, then you plug the scanner into the computer with the usb cable, then you turn on the scanner and windows will see that a device has been ada via usb, it will set up the newly isnatlled device and you will be all set. alot of people forget to isnatll before they hookup and cause a few isues hope this helps you. also please uninstall the scanner and follwo the steps and you will probably be fine. good luck.
Aug 22, 2009 | Canon Office Equipment & Supplies
The buttons on the Scanner itself will no longer work.
You should be able to reconfigure the button settings by clicking on the "Settings" button in the CanoScan Toolbox application. Although the default setting is Scan, Copy and eMail, each of the buttons can be configured to do whatever operation you choose.
Oct 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Set up scanner
install software then restart the computer , once restarted plug the scanner in the computer and wait for it to see the scanner then after you should be able to use it
Oct 05, 2008 | HP Office Equipment & Supplies
Help
You'll have to do that in the software that handles the image after scanning. Do you start scanning from your computer, or direcly on the scanner? While executing the scan from the computer, you can select the save-path there. While executing directly on the scanner you need to to go to the settings of your scanner, i think.
Mar 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Aug 15, 2007 | Metrologic Instruments MS5145 Handheld
HP OfficeJet 6110 All-In-One InkJet Printer Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
