Question about Nokia N73 Music Edition Smartphone
My nokia n73 ic was short - Nokia N73 Music Edition Smartphone
My n73 phone
Posted on May 06, 2010
Dead
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jun 15, 2011 | Nokia N73 Cellular Phone
Nokia n73 phone dead
1. Water damage
2. Fall down
May 24, 2011 | Nokia N73 Cellular Phone
Nokia n73 " unable to
DEAR FRIEND,YOU WILL HAVE TO CHANGE THE BLUE-TOOTH I.C OF YOUR PHONE.
Feb 22, 2011 | Nokia N73 Cellular Phone
Plz mujhe nokia n73 ke network problems jumper solution dijiye
sir
nokia n73 ka pf ic remove karke jumper mar rha hu to no network fond a rha hai
plz help me
Sep 19, 2010 | Nokia N73 Cellular Phone
The keys 1&3 are not working on n73
Hello Friend, For solving your problem just service your phone if you are familiar to opening your mobile phone then unscrew the phone open the keypad the open the keypad sticker generally white colored on the circuit then connect or shot the two terminals of key which is not working for a short time then check it whether it work or not? probably this may solve your problem if not solved then their may be IC problem you have to change your keypad IC this may done bye any mobile expert so go to nearby mobile repairer. Hope this will solve your problem Best of luck ...
Jul 07, 2010 | Nokia N73 Cellular Phone
From where I can get IC for Nokia mobile
Go to a Nokia repaire shop , and you'll find what you are looking for .
rate if usefull please !
Jan 11, 2010 | Nokia N73 Cellular Phone
Display not visible
Change your Display ic or L.C.D if broken Thanks
Apr 27, 2009 | Nokia N73 Cellular Phone
Nokia N73 Music voice problem
dear sir ,
pls upgrade the software&change the MIC of the phone ,if not solved than change the IC( retu).
Jan 20, 2008 | Nokia N73 Cellular Phone
N73 Hanging Problem
If the bottom of your N73 is getting hot soon, it means that your Power IC catchs more Voltage than it nees so, the problem comes from your Power IC, and you have to change it!
You can't do that on your own, coz you need an special heater in order to lock off the power IC and change it. Just bring it to an EXPERT technician!!!
Another problem which will occure after this problem is that your charging IC would be deactivated and you have to change it too!!
Again, take care about microphone IC as it is similar and near to your Power IC!! This would disable your hands-free and microphone!
Regards,
Schahinap
Jan 01, 2008 | Nokia N73 Cellular Phone
Nokia N73 Music Edition Smartphone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
