Question about Whirlpool LEN2000PW Dryer
Dryer door won't stay shut latch won't catch - Whirlpool LEN2000PW Dryer
    Top Expert:
  • 2,931 Answers
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
Posted on May 06, 2010
  • Whirlpool Master
  • 8,220 Answers
The latch is easily replaced
2 Suggested Answers
SOURCE: dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Posted on Aug 01, 2010
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut - JamesMaurer.com
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Sep 08, 2014 | 2000 Toyota Camry
Why door will not stay closed
Many of the latches have a tooth shaped catch. If the tooth part is broken off the latch won't catch.
Aug 10, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
My dryer door won't stay shut, what do I need to do
your latch is probably bad. the part number is WE1M536 it will cost about $5 you can get it at searspartdirect.com
Jul 14, 2011 | GE DCVH515EF Electric Dryer
Door will not stay shut...........simply pops open after 10 or 15 seconds. No visible damage. No debris along the door pathway. Perhaps a new plastic latch. The old one looks fine.
You just need to replace the catch and the strike it is easy to install.
Detailed Viewhttp://www.easyapplianceparts.com/PartInfo.aspx?Inventory=334230&SourceCode=6 EAP334230: Door Catch Kit This dryer door latch kit comes with one plastic door latch, and one metal door strike.
Easy Part #: EAP334230 Compare At: $4.75 Your Price: $3.96 You save: $.79 Availability: In Stock 334230_1_m.jpg
Above example contains part: EAP334230.
Click image to see large version
Model number:
Part description in this model:
Part location: #
Series number: -->
334230_1_s.jpg 334230_2_s.jpg 334230_3_s.jpg function KeyPress(e) { if(e.keyCode == '13') { if(document.getElementById('_ctl0_menu1_SearchNum').value != "") { document.getElementById('_ctl0_menu1_SearchButton').focus(); } else { e.returnValue=false; //required for IE if(e.preventDefault) { e.preventDefault(); } // required for gecko } } } '); //-->
Dec 03, 2010 | Kenmore 62602 Electric Dryer
My kenmore drying door won't stay shut I've replaced the latch and catch and it will stay shut for a little while and then pops open?
if you don't mind 'jury rigging' it, you could tape a simple velcro strip to it. 1 piece of the 'hook' side on each side of the door. and 1 long piece of the 'loop' side to go across both pieces of 'hook'. i suggest this pattern because no one likes to grab the 'hook' side with their fingers.
sometimes working is more important than working correctly. good luck
Nov 06, 2009 | Maytag Neptune MCE8000AY Electric Dryer
I have a Kenmore Elite HE4.THe door will not stay shut. It doesn't click anymore when I push the door to close it. Any ideas?
The catch side, not the latch side, the catch on the frame may have backed off some what. It's not unusual for this to happen over time. Take a peek around the catch and see if there are any adjustment options such as two slots where the mounting screws are, a hex key slot behind it to adjust the reach and so on.With a flash light close the door very slowly and from above as best you can see if the spring fed latch is near enough to the catch. Also try hip checking the handle to try closing it.If then it latches you may have a section of seal gasket that is misplaced or swollen. See, not being there makes this a very difficult call. I've given about the most options I can think of and I hope for you guys that one of them works. Also if your closer latch is similar to the operation of a screen door latch, don't be afraid to pry the latch lightly in the direction towards the catch/latch. Good luck and Thank you, Dana
Aug 26, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer door will not stay shut. It seems like the little clip that is supposed to keep it shut no longer catches. Do these clips wear out? It looks fine and seems to fit- just doesn't catch
Take a second look at the door.
Is the spacing the same between the door top and bottom as it fits into the front cover?
Over time, people/children will rest weight on the door as it swings open, bending it downward. You may see rub marks where the door is hitting the bottom jamb.
Pull hard to bend the door back up, OR unscrew and re-tension rhe 4 screws that secure the hinges to the front frame.
The door should close more completely now, Spray a little silicone lube on the latch.
good luck and I hope this solves the problemn.
Aug 13, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool LEN2000PW Dryer Logo
829 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
