I have a compaq presario 2200, which is several yearsold ( 2004) I believe, and after using it this morning I powered it down and came back this evening and it wouldn't turn on, No charging light on and nothing on screen. Just dead.
  • 12,061 Answers
You will have to troubleshoot and find out where the fault is. Here is what I do….. First, check the Power is ON, cable is OK and IN PC, Then open PC up, and remove all power connections from everything EXCEPT the Motherboard Connector.(s) (Remember where they go, draw a diagram etc) Power the computer up, and does it switch on? NO, Then, remove the RAM, does it Boot up? YES Faulty RAM, replace. If it still does NOT then your Power Supply Unit is probably Faulty.(But it may be the motherboard) either way we need to test more with a known good power supply. With know good PSU, plug this one into the Motherboard Connection(s). Does it work, YES. Problem Solved. OK back to Frst: Because it DID go the PSU WAS OK, The MB was OK & the RAM was OK, Now then we plug in each of the other Items, DVD Hard Drive, etc, etc. One-at-a-time, until we find the one that stops the PSU. (It has protection and will "Shutdown in event of a fault") The one that stops the PSU is your culprit, replace whatever it is.
www.hp.com/ctg/Manual/c00226047.pdf
Service manual above, use this to learn how to troubleshoot, and possibly repair your laptop. use the above procedure to see if it is battery or PSU.?
Owners manual below. http://support.dell.com/support/edocs/systems/ins2200/en/om/D88330a.pdf
Posted on May 06, 2010
  • 13,433 Answers
Hello
lets start by taking out the battery from the laptop and then unplug the power, leave it out for a few minutes and press and hold the power button down for at least 15 seconds.
then reconnect the power adapter without the battery and try turning it on. If noting happens. Then the issue is either the power supply has gone bad, or the laptop has failed. 6 years is pretty good from such a laptop.
Try another power supply, you can get a generic power supply at almost any computer store. Just make sure you match the voltage and the polarity of the connector when using a universal adapter.
if you don't want to spend much money on a new power supply we can test the old one. You are going to need a 24volt car lamp, solder two wires to the appropriate places on the lamp then connect the wires to the plug that is supposed to go to the laptop. If you get a steady light the power supply might be OK, use a multimeter or volt meter to check that the voltage matches the output, also measure the voltage while connected to the lamp, if the voltage goes down or doesn't stay steady, then most likely the power supply is bad. Go try the new power supply.
If the laptop still remains dead the issue is internal, most likely the main board, we don't have many options on what could have failed. Your going to need a experienced repairer to get the machine working again, these boards are very complex and hardly no one is going to attempt a repair, most shops and people will tell you to replace the motherboard which is definitely not worth it in this case, you can get a cheap new laptop with warranty for less than the repair.
  • 1 more comment
  • Ekse May 06, 2010
    Hello? I didn't get a message from you, just a reject email, do you think there is some kind of a magic fix for this? if you have questions please post them here with the add a comment link.
  • Ekse May 06, 2010
    hello?
  • Ekse May 09, 2010
    hello? i've not heard anything back from you? do you need further assistance? if not, please click on the accept button below my solution.
Manuel for compaq presario 2200 series 3297
Hi Carol,
Here's the manual in pdf.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | HP Compaq Presario 2200 Notebook
I'm looking for a manual for a COMPAQ PRESARIO
You need to go to hp.com and search for your model then click on downloads tjem manuals down the right side of the page.
If this link works it should take you direct to all the manuals for the 2200. Thes are the user,setup and maintenance manuals so lots of good info available.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=430816
Sep 06, 2011 | HP Compaq Presario 2200 Notebook
Is there an internal microphone and if so where is it located trying to record myself i have a compaq presario 2200
Hi, the HP Compaq Presario 2200 PC has no built in or internal microphone. You will have to purchase an external one to record audio. The microphone jack, when viewing the laptop from the front, is located on the left side.
There are small round holes which are jack ports. From the front to the back, the microphone port to plug in a microphone is the second hole back. Here is a manual in case you need more help with your laptop: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | HP Compaq Presario 2200 Notebook
My Compaq Presario 2200 powers on ("on" led, drive
1) put the laptop on a bed or a similar surface to close the air openings below
2) wait some time (15-30 min or 1hour) and let it get warm enough
3) restart.
it worked for mine. hope it works for you too.. the laptop seems stable and does not give any more beeps (for now).. good luck !
Jan 02, 2011 | HP Compaq Presario 2200 Notebook
Compaq presario 2200 dead after switching battery No power or lights. All I did is change out the dead battery for a new one.
u can try only with ur adapter ur laptop go on? if work u can change new battery of dunt work may be from the electric in ur motherboard
Jan 16, 2010 | HP Compaq Presario 2200 Notebook
Reset power on bios password on compaq 2200
theres a small battery in you computer you have to pull for like 5 minutes you can find out what it looks like on youtube.com or wonderhowto.com
Mar 24, 2009 | HP Compaq Presario 2200 Notebook
Laptop not powering
try a simple power cycle. Take out the battery, leave power adapter plugged in. Hold down the power button for about one minute. Then hit the power button normally this should correct the problem
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Compaq Presario 2200 won't hold a charge - on or off AC
I have a Compaq Presario 2210US. The wireless toggle button is in front on the right side, slightly under the top of the computer. Feel for it with your fingers or use a flashlight. It glows a bright blue when on.
Oct 30, 2008 | HP Compaq Presario 2200 Notebook
Presario 2200 Notebook won't power up
try disconnect power then remove battery,plug power back in and try to boot.if nothing happens put battery back in and see if it charges.if it does leave to charge for a while,try to boot if it dont boot you know its neither the power or battery and shouldnt cost too much to repair(probably a capacitor dead , possibly transistor blown diodes only allow electricity to travel in one dirrection so only break if shock(drop or bang hard) resisters have about a 100yr life.
Feb 22, 2008 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
