Question about Canon PIXMA MP160 All-In-One InkJet Printer
My Printer is flashing E 1 5. What do I do? - Canon PIXMA MP160 All-In-One InkJet Printer
  • 2,404 Answers
E15 usually means the ink cartridges haven't been installed properly. Take them back out and make sure they get installed properly. If they are installed properly, see if you can use other new cartridges, if that doesnt work then that means the mainboard inside of the printer is bad and you would have to get a new printer.
Posted on May 06, 2010
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Kyocera fS-920KX. Not printing
    There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
    1) Green On, Red Off = Printer Ready.
    2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
    3) Green Fast-Flashing, Red Off = Printer off-line.
    4) Green Slow-Flashing, Red Off = Processing Data.
    5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
    6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
    7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
    8) Green Off, Red Off = Printer power is off.
    9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
    10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
    So what is your printer condition? Better know what is going on your printer so can solve the problem
    YBC (/\)
    Jun 01, 2009 | Kyocera FS-920 Laser Printer
    Check printer 6000
    For fixing your problem do the following:
    1. un-install the printer drivers
    2. restart the system
    3. Remove the connections of the printer from the cpu
    4. Install the drivers for the all in one printer
    5. Restart the system
    6. Connect the cables and Power on the Printer
    Let me know if your problem is solved and rate me as FIXYA!
    Mar 25, 2009 | Canon PIXMA MP170 All-In-One InkJet...
    Kyocera Ecosys FS 920
    So what is your printer condition? Better know what is going on your printer so can solve the problem.
    YBC (/\)
    Mar 24, 2009 | Kyocera FS-920 Laser Printer
    Reset button constantly flashing and wont reset!
    Hi Cressy
    1.Power off the printer, then Unplug the power cable from back of printer and from wall outlet.
    2.Press and hold ON button for 30 seconds
    3.Now plugin and check the printer
    Thanks
    Riz
    Jan 06, 2009 | HP DeskJet 970cxi InkJet Printer
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Nov 01, 2008 | Canon BJC 55 InkJet Printer
    Flashing light
    Here is what HP has on the subject of the triangle light flashing:
    c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
    c00028328.gif Door open, media out, no print cartridge, or media jam
    The printer is in an error state that requires operator intervention or help. Check the following:
    • The print cartridge door is completely closed.
    • Media is loaded.
    • The print cartridge is correctly installed in the printer.
    • There is no media jam.
    Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
    13.JJ.NT JAM IN TRAY X
    The Attention LED is blinking. Check paper loading then open and close top cover.
    When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
    When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
    If the light pattern is different let me know (other lights on as well)
    -Hope this helps.
    May 28, 2008 | HP LaserJet 1012 Printer
    My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
    hello!
    You will see 3 led lights on the printer. They will blink continously if:
    if the print cartridge status light is flashing
    -- check if the top cover is open, Close the top cover.
    -- there may be a problem with a print cartridge
    1. Verify that the correct print cartridges are installed.
    2. Check if a print cartridge is low on ink or improperly installed.
    if the resume light is flashing
    -- the printer may be out of paper
    1. Place paper in the In tray.
    2. Press the Resume button on the front of
    -- the printer may be ready to print the second side of a two-sided document
    1. Follow the onscreen instructions for printing the second side.
    2. Press the Resume button.
    if the power light is flashing
    -- the printer is preparing to print
    -- The light stops flashing when the printer has received all data.
    if all lights are flashing
    -- the printer may need to be restarted
    1. Press the Power button to turn off the printer, then press the Power button
    to restart the printer.Proceed to step 2 if the lights continue to flash.
    2. Press the Power button to turn off the printer.
    3. Disconnect the printer from the power source.
    4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
    May 06, 2008 | HP DeskJet 940c InkJet Printer
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    165 people viewed this question
    old marine
    old marine
