Question about General Electric Microwave Oven
I own a JVM1430WD002 GE SPACEMAKER XL MICROWAVE OVEN. I'VE OWNED IT FOR 7 YEARS & IT'S 8 YEARS OLD. All functions are working except the unit will not heat anything placed inside. I've unplugged the unit and plugged it back in but this has not solved the problem. Is there any further troubleshooting I can due to isolate the problem (diode? capacitor? transformer? magnetron? fuse?)
  • GE Master
  • 8,220 Answers
It could be a bad magnetron tube. If the mag is open then of course no heat but everything else would function. GE service manual Granny's nuke notes
Posted on May 06, 2010
The exhaust fan works, the light below the microwave that shines on the stove top works. It appears to be functioning properly except that it won't heat up food. The GE Spacemaker Model JVM131001 is...
I'm all for fixing appliances but in your case I would suggest replacement. After 24 years of service the magnetron is probably only putting out half of its rated wattage. It could also be one of the reasons of the no heat condition.
Jun 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat coming from Microwave oven-GE Spacemaker Model XL 1800
in the microwave there is a part which produses the heat which will be called as magnetron you check that part.
Aug 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave won't heat food
hello kmwnky,
You say that Everything went out at first ( which I assume means that all functions went dead) and then functions started to operate again later... if that is correct and you smelled something burning.. you may have a thermal fuse that failed, filament transformer that failed, magnetron tube that failed or a highvoltage capacitor that failed.. None of these components are something the untrained person should attempt to trouble shoot or replace since there are dangerous energies stored inside the electronics compartment even after power is removed.. Your Micro is > 8 years old and it's probably not worth the cost of repairing at this point. You'd be better served replacing it.. The cost to repair would exceed the cost to replace.. ( I feel like the grim reaper here..sorry..)
Regards,
Rick
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
329 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
