Question about Sony Ericsson K800i Cellular Phone
Blue blank screen
Few days ago I was checking my other sim to check my messages but when I removed the old one the switched on screen was blue and blank and si still the same after 3days.The battery is full,I tried to update the software but the update manager downloaded from the SE site says it has updated version already.what to do?
    Brigadier General:
  • 7,752 Answers
Replaced the LCD
Posted on Jun 08, 2008
SOURCE:
Monitor works sometimes and sometimes not
Reboot pc until you have a picture, then try updating the drivers for the monitor and your gpu if applicable, outdated drivers can cause erratic and intermittent behavior. Navigation to drivers access varies slightly based on operating system.
Sep 02, 2017 | Computers & Internet
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
Hi, my wife is using her Nokia 6700 classic overseas [currently in India] [we live in Australia]. We set up international roaming, which was working for the first few days of her trip. But, after a few...
Hi there Glen,
Here are few suggestions:
1. If this is a Prepaid sim, make sure your wife has enough load on the sim. Sometimes, even if you still have a few loads left, these networks does not process the text message especially for roaming sims. So let your wife load a new prepaid card.
2. Make sure your wife's phone is configured with the correct SMS Message Center. Ask Optus about it and have your wife double check on her phone's Message center setting.
3. If this is a postpaid, and that your phone can still call you from India to Australia, and that the suggestion in no. 2 was checked, then by all means, the problem is with Optus, considering that SMS sending was working days ago with your wife.
Please let me know if this helps. Thank you for using FixYa.
Dec 09, 2010 | Nokia 6700 Classic Cell Phone
I have lost the ability to recieve or send text messages and check call log
firast remove the sim and memory card then fortmat the phone using this method
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try it your problem was solved
Oct 20, 2010 | Nokia N95 Cellular Phone
Blackberry Pearl 8120 spontaneously deletes sms and call log
STEP 1 : First check for the free space in the handset
  1. selece the option icon in the main menu
  2. scroll down and then select memory
  3. check for the free space in the device.If the memory is full then delete some application.
After doing all the above steps with out switching off the handset remove the batery and sim after few seconds reinsert them again.
For refreshing the handset .
STEP 2:
Check the old messages are deleting are new one if old messages are deleting then follow the below steps.
  1. Select the message icon from the main menu
  2. Press menu button and select the Option
  3. Select the general option
  4. scroll down and select KEEP MESSAGES as per your wish (30days, 15 days, forverer)
  5. After selecting any one of the option press menu button and select save .
if you select 15 or 30days the old messages will delete after 15 or 30 days.
If you select forever till you delete the messages it wont delete untill you delete them.
Step 3:
if the messages and call logs are deleting in between then there is problem in the handset software.You have to take the backup and then reinstall the software of the handset.
Mar 13, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
White Screen on Razr, What is a "Strip Problem"
Before you open it and look inside it check to see if the magnetic switch is stuck. Check it with a kitchen magnet to the upper righthand corner of the keypad. There is a magnet in the lower righthand corner to activate it. Do some of the function work when it is closed? If they do then it is not the cable but the switch. Does the outside screen look the same as if it is closed then it is this switch? Could be a bad one, something stuck in there, or it could be stuck.
May 09, 2007 | Motorola Mobility RAZR V3
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
