Question about Brother MFC-9440CN Laser Printer
Scans are crooked
Scans are not centered when fed through the doc feeder. they come out crooked.
  • 215 Answers
SOURCE: 2 black streaks on copies and faxes
open (lift up) the document feeder. on the left side of the large glass, you should see a thinner, narrower piece of glass. sounds like you have white out or something like that on that glass.
hth,
razors
Posted on Jan 29, 2009
RPFinney
  • 385 Answers
SOURCE: document feeder jams
When you put your paper in, check the side clamps are set correct, if there is a gap at one edge, your feeding will be all over the place.
Tuck up the clamps to clamp the paper, not too tight where you bend the paper, but tight enough to hold it correctly.
Regards
Richard
Posted on Mar 13, 2009
bbaditz
  • 75 Answers
SOURCE: Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Posted on Mar 04, 2010
  • 141 Answers
SOURCE: black lines on scans & copies
Please perform Solution two: Clean the ADF rollers and separator pad, provided in the follwing HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00228023&cc=uk&lc=en&dlc=en&product=421991
:) Dr Tony
Posted on May 14, 2010
clrvuedoc
  • 175 Answers
SOURCE: How do I get rid of a vertical black line on my
Try getting a can of compressed air and spraying the scanning area to clean out any debris that might be causing the problem.
Posted on Mar 01, 2011
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Feb 17, 2015 | Sharp Office Equipment & Supplies
Why does my printer produce wrikled printouts
Your paper feeder is only working on one side causing the paper to try to go sideways. This will wrinkle the paper just like it is fed in crooked.
Jul 19, 2014 | Dell 1160w Mono Laser Printer
I get a singleline down the center of any scan i was told it was a blown pixel(?)
This could be cause by some debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans. Please refer to this article found in the Lexmark website about Vertical Lines Down the Page when Paper Fed via Autodocument Feeder (ADF).
Jul 24, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Hp 6210 prints a black line down the center of the page. 1st 50 copies okay, then line started.
First diagnose if the line comes when using the doc feeder or the glass. If it only comes when using the doc feeder then you have a small dirt spot on the glass where the page is scanning over the exposure lamp. Just clean it.
Feb 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Vertical lines about one half inch apart down center of the page when fed through the document feeder. No problem with fladbed copying or scanning.
If you open to document feeder and look at the glass when scanning via flatbed, just to the left will be a smaller piece of glass. That is the glass used when scanning through the feeder. Clean that glass as there is probably a couple of spots on it.
Jun 30, 2009 | HP LaserJet 3030 All-In-One Printer
Problem with scanning documents through feeder
you can scan only one doc at atime on this machine.
Nov 03, 2008 | Brother MFC 7420 All-In-One Laser Printer
Black lines showing up on documents fed thru the document feeder.
Clean the small glass under the doc feeder very very well...
Jul 03, 2008 | Sharp AR-M277 All-In-One Printer
Scanning documents
Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
Thanks J
Jan 24, 2008 | Sharp AL-1551 Laser Printer
Brother MFC-9440CN Laser Printer Logo
160 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
