Question about Roper Dryers
My roper is a rgd4440sq0and the start button is not working. it was running i opened it to check the clothes and now it will not start again. when i open the door then close it the button makes a click but will not start.
  • Roper Master
  • 8,220 Answers
Check the lid switch first is what I would do. It could be the switch or the arm that makes contact with the switch called an actuator. They do break.
If all of that was good I would look for air restrictions that might cause overheatingmy roper is a rgd4440sq0and - d0a2e92.jpgand correct that. Then I would unplug the dryer and check the fuse3001bb1.jpg
Posted on May 06, 2010
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
My Roper dryer has power I can here it, but it does not spin the clothes dry...doesn't turn on. How do I figure out what is wrong?
try this,open the door,with one hand push in the door switch,with the other hand spin the drum,have someone else push the start button,if it runs you have a bad motor
Feb 22, 2011 | Roper REX3614KW Electric Dryer
When one opens door ------dryer keeps running
Simple repair. e45a747.jpg5fc411d.jpgf1e9000.jpgIf you gonna remove the front to do the repair I suggest you lift up on the panel to keep from damaging the clips that hold the bottom secure46c7a66.jpg
Jul 24, 2010 | Roper Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Roper REX5634KQ0 runs for two minutes in any cycle and then stops
This problem sounds like a bad motor bearing causing the motor to overheat, when the motor overheats there is a thermal protector that opens and the motor will not run until it cools down.
Jan 06, 2009 | Roper REX4634KQ Electric Dryer
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Aug 21, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
14 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
