I bought an Optoma HD 66 projector. Worked great for about 2 and half months, today I noticed a blob of discoloration in the top left corner. What happend, can i fix this?
The bulb cutting out is usually down to it overheating. I thought it was a loose connection at first so I gave it a slight clout....... After Id bought a new bulb due to my general stupidity I realised that all I needed to do was clean the filter out on the side. Its been fine since. Ive had it apart a few times to clean the dust out etc but now Ive got the discouloration problem. Think another screwdriver job is in order...
Posted on Jul 30, 2012
  • darthkenneth
    darthkenneth Jul 30, 2012
Bought an hd home cinema projector model number hd66 the bulb keeps going off after a while of viewing any suggestions
Posted on Nov 24, 2010
  • writerbryan Dec 23, 2010
    I have a Prowler HD66 projector also. Same problem. The fan went bad on mine and I'm currently in the process of contacting the company to get either the fan or the projector replaced. This happened about 30 minutes ago (I've only had the projector for two days) so my guess is that you might be having the same problem. Check to see if all of your projector's fans are running. If not, then do what I'm doing and contact the company. The warranty for these projectors lasts for a year and covers factory defects. The trick is going to be contacting them. I've tried today and so far, no answer.
  • 144 Answers
My optoma es526 came with a 7year colour warenty,try ringing up optoma and send your projector to them or try replacing the colour wheel.
Posted on May 08, 2010
  • clintonrh Sep 29, 2010
    Could simply be debris or dust stuck on the outside of the inner part of the lens or between the lamp and the color wheel. Take the lamp out and look at the color wheel. Use compressed air to remove debris. You can also get rid of the debris between the color wheel and lens by blowing compressed air in the side vents of the unit. The HD66 and HD65 are prone to this happening if you have a ceiling fan close to the projector. Dust blobs from the fan can fly off and get sucked into the projector. If the picture is still working and, for the most part, the picture looks good, then the color wheel is probably fine. You should clean the color wheel about every 6 months anyways as a film will gradually build on it, causing the brightness and colors to seem dimmer. Clean with a q-tip and denatured alcohol. Be careful not to touch the color wheel with your fingers.
My projector suddenly all the whites went pink
Any solutions yet? mine just did this after 2 months
May 04, 2012 | Optoma PT105 PlayTime Projector
Hi i want to connect a tv to my optoma hd 66 projector
hi,
You can't be able to connect a tv to your projector, because it doesn't have a monitor out.
There is only one way. If the source is a DVD player then connect the its HDMI output to the projector and the component video out to the tv. You can't be able to get video out from the composite video output of your DVD player, when you are using HDMI. When plug the HDMI it will switch off the composite video out. The component video out remain ON whether you connect HDMI or not.
ok
Mar 31, 2011 | Optoma HD72 Multimedia Projector
Pwering up and then turns off.
I have a similar issue. It might be overheating. Did you try cleaning it, using a duster? Let me know if you found a solution.
Mar 20, 2010 | Optoma HD80 Projector
Optoma hd70 starts flashing colors
I removed the front cover and top panel, Using the Radio Shack dust removing spray, removed all dust from interior including circuit boards, color wheel ect, now it,s operating like a new projector.
Dec 21, 2009 | Optoma HD70 DLP Projector
Optoma projector HD806
its not the color wheel. Its the sensor that counts the black tape on the color wheel. The sensor has dust on it. It can't count how many times the wheel is going around because the dust is blocking it. the sensor is located by the wheel. if you have any questions you can callme 610-842-7442 ask for dan.
Dec 01, 2009 | Optoma hd806 DLP Projector
ThemeScene HD65 projector, red thermometer light is on
I simply shut the projector down (had to pull the power cable) and when starting up again it was working fine and has since then.
Oct 03, 2009 | Optoma HD65 DLP Projector
My optoma hd65 projector worked fine for 2 months, now it will not detect hdmi signal from a motorola cable box or sony dvd player. Any idea's??
hi i am running a scart lead from my sky to my projector with a s-video lead going in the back of my projector but am only getting black and white picture!! can you help
Jun 06, 2009 | Optoma HD65 DLP Projector
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
Hair inside optoma hd70 lense
I had an issue with "dust blobs" on my HD70 and was unable to locate instructions or a tutorial on how to remove them. I figured maybe this could help you if the hair is located within the same location as the dust. Please check out my blog at http://tantht.blogspot.com/ for instructions on how to remove dust blobs from a HD70 as this process worked perfect for me and I no longer have these annoying spots when watching movies!!
Jan 26, 2009 | Optoma HD70 DLP Projector
1,274 people viewed this question
k24674
