When I try to send patterns from computer to my Artista 180 embroidery machine a message that says "serial Port engaged" then anothert message says communications error. I have windows xp.
    Sergeant:
    Champion:
  • 329 Answers
Try to unstall the software driver of your Artista, then install it again.
Posted on Mar 26, 2008
Artista 165 embroidery unit will not communicate with my sewing machine.
Did it ever work ? Have you had the firmware updated in the machine - if-so, the V4.04 firmware will not communicate with a V3 embroidery unit and you'll have to get them updated to the same version. Failing that, I'm afraid one of them has a fault on the serial interface. Note also that a 165 sewing machine will not work with a 180/185 embroidery unit because the earlier unit has a 2MB memory internally, whereas the later unit has a plug-in 4MB memory.
Feb 09, 2012 | Bernina Artista 180
Cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Nov 19, 2011 | Bernina Artista 180
USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Jun 23, 2010 | Bernina Artista 180
Have 4.0 software. When trying to load pattern to 180 Bernina I get the message no link to serial port.
Which version of Windows do you use? There is an additional software to download from the Bernina website for Windows XP which solves that problem.
Feb 08, 2010 | Bernina Artista 180
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Bernina 180 usb to serial cable not working
it's in your computer control panel - you need to assign the com port to the cable - it took me a few tries.
In the long run, I bought the Editor Lite software for $120 on ebay - it comes with a USB dongle - that solved all my issues other than assigning the com port to the serial port. It all works like a charm now.
Oct 10, 2009 | Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
I am trying to send patterns from my computer to my Bernina Artista 180 and I keep getting the message (serial port engaged) ans communications error. I am musing windows xp PLEASE tell me what to do. ...
Does your bernina have a USB port or do you have a card reader? I have ran into this problem before. To use the patterns off of the computer, they have to be in a format that your embroidery machine can read. The only way I have found to do it, is use a card reader plugged into a USB port on the computer and it transfers files that wayinto a format the Bernina will read and be able to embroider from. Good Luck. Win XP started this problem and unfortunately, Vista hasn't fixed it.
Mar 26, 2008 | Computers & Internet
Artista 180 driner
hi you need to get the right software for artista 180.I have just sold
my 180 and i still have the software on my computer. You need
the software called CPS 4.1...EMAIL me at lfr6@bigpond.com i might be able to get a copy off my computer for you
Lawrence
Feb 16, 2008 | Bernina Artista 180
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
