Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No Remote need to set up for DVD Video (Mitsubishi Medallion HD 1080)
Thanks TroyLove1
I have the cords which I have attached from the DVD to the TV (yellow, Red, & White) but not sure what channel the TV needs to be on or do I have to set it up thru the menu button. I need step by step instruction...I am kinda SLOW in this area :-)
    Genius:
  • 1,153 Answers
What you do is match color with color, just make sure if you are putting in Video 1, 2, 3 etc. then you have to set your tv to that input with that Device/input button.
Posted on Mar 27, 2008
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
I have a HD 1080 Medallion TV and I just changed it to Direct TV and the color is now in Black and white. Is there anything on the remote to fix this?
More likely the cables from the Direct TV box and the TV are incorrectly connected. My guess is that you have red, green, and blue cables that carry to video signal and they are incorrectly connected or one of the cables is bad.
Sep 10, 2013 | Mitsubishi Televison & Video
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
SAP on Mitsubishi Medallion 65" 1080
Set the tv to stero setting this should turn sap off. This can be changed by the remote or in the enu under audio settings. MONO<STEREO<SAP are some of the choices select stereo.
Second[ary] audio program[ming] (SAP) is an auxiliary audio channel for analog television that can be broadcast or transmitted both over the air and by cable TV. It is often used for an alternate language. HOPE THIS HELPED GOOD LUCK AND THANK YOU
SAMUEL
Jan 05, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
158 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
