Question about Gateway 503GR PC Desktop
DVD and CD drive don't work
When I click on the E: drive (CD) it states to insert media which there is a CD in the drive. Also, when I click on D: drive (DVD) nothing appears in windows explorer and also it won't burn to a DVD.
  • woody188 May 11, 2010
    Are these on the same IDE channel? It's odd both would go out at the same time unless there is a problem with the IDE channel that they are on. Might be as easy as switching to an open IDE channel and checking that the BIOS detects the drives.
  • 29 Answers
STEP 1:
Go to device manager:
START - RIght click on my comp - manage - device manager :
When in device manager, look for:
IDE ATA ATA/ATAPI controllers
click on plus sign to expand the tree
right click on the IDE controller that is handling the CD/DVD drive in question
select uninstall
reboot your computer .
STEP 2 :
Delete Upper and Lower filter :
start : run -
type in regedit -expand hkey local machine -
expand system - xpand current control set - look for control , expand it - under control - expand class - look for the address ::: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- click on the address - towards the right pane you would find upper and lower filters - right click on both and delete it - after uninstalling the upper and lower filters restart the system - aftre the restart check for the functionality of the drive -
Step 3: if bot the steps above does not work then a firmware update on the dvd drive can be performed - the firmware is a software update for the dvd drive and you would be able to find it on the manufacturer website -
Hope the information provided above was helpfull .
Thankyou .
Posted on May 07, 2010
Dell studio 1555 doesn't read DVD or CD , when I insert CD / DVD it looks like it is reading the media but when I click on Drive icon, it ejects the media.
First reinstall the DVD driver to see if the DVD drive works.
If not then -
Try removing the DVD drive and inserting it back to make sure it properly connected then boot up the laptop and go into the BIOS and see it the DVD drive is detected, if the DVD drive is not detected then the DVD drive is faulty and needs to be replaced.
Jun 11, 2012 | Dell Studio 1555 (883685982850) PC...
Cant read the cd
This can be a media or a DVD drive problem.
First check if when you insert the disc the lights of the drive flash. Second clean the media or CD. Third there is Disc Cleanup to clean the laser of your DVD drive. Check the power and data cable are connect.
Is possible the the drive is damage check for no normal sounds when you insert a media.
If is possible use a CD or media on other drive if it work you need a new DVD drive.
Mar 08, 2011 | Acer (KV.16X04.007) DVD Drive
Windows media player cannot detect my dvds in the dvd rom player. i have windows vista
Open "My Computer".
Insert a CD-disk into the drive, while holding-down the LEFT-SHIFT key.
Does the label under the CD-icon change?
Remove the CD-disk.
Insert a DVD-disk into the drive, while holding-down the LEFT-SHIFT key.
Remove the DVD-disk.
If no changes in the icon, after the above, it's time to spend $40 to replace the "dead" drive with a new CD/DVD writer.
Jan 09, 2010 | Dell Inspiron 530 -Intel® Pentium®...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
DVD-RW drive does not read disks
the DVD-RW is faulty, take it in and get another one to replace it. the clicking noise may be coming from the rack gear inside the device and causing a malfunction.
Sep 13, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
My HP Model w1097 does not read CD/DVD drive TSST corp cddvdw ts-h6532
Most likly the drive is bad. Try click start. click on my Computer. Right click the CD/DVD drive. Click properties. Click on Hardware. Does it say. This Device Is Working Properly? If not click on troubleshoot. At the HP web site you can get the latest driver for your CD/DVD drive. You can also insert a CD Go to my computer as stated earlier Right click CD/DVD drive to see what is on the disc. Or click play to see if it works. make sure you choose a default player. Hope this helps.
Jun 22, 2009 | Gateway GT5408 PC Desktop
I have Sony CD-RW and Sony DVD-RW - Nero will not copy files
Your DVD-RW needs to get repair from the authorised personnal.
Apr 23, 2009 | CD Technology DVD-R (44105)(100PK) 4x...
Dvd burner is not recognized by windows XP sp2 when blank media inserted to burn a movie.
well u need to check for the latest software available for your dvd drive try and find the latest software on net according to your company,and check wether the software ur using comaptible with ur windows
Jan 23, 2008 | Computers & Internet
Dell Inspiron 1200 CD/RW \ DVD Rom combo drive
Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. See if that sorts it.
Feb 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Gateway 503GR PC Desktop Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
