Question about Hayward Phantom Robot Cleaner without Booster Pump
I pulled my Phantom out of storage last week, placed it in the pool and it just goes around in circles. Water is slightly spraying around the little marble in the cam spin-out part but the clock hands go around properly. What part should I replace?
  • 640 Answers
If it is going in circles, it is most likely a hose problem. Try laying the hose stretched out on a sunny day. Leave it for several hours. It may help to straighten the hose. If you can't get is reformed, you might have to replace the hose or the connection in the back of the cleaner. This is a common problem with this kind of automatic pool cleaner, especially if you coil the hose when you store the cleaner. That is never a good idea.
Posted on May 25, 2011
Why does my pool sweep go around in circles on one wheel and not pick up anything in a week?
make sure the ballast ball doesn't have any water in it if so replace also make sure little exhaust on back is pointed at 11 o clock
Mar 31, 2016 | Polaris VacSweep 280 Pool Cleaner with...
How to keep the tail from shooting water out of the pool on a phantom pool cleaner
Some "water shooting" is normal with any pool cleaner no matter what brand. It sounds like your tail valve may be turned up too high. At the base of the tail there is a small plastic screw valve. Try turning it clockwise a little at a time . The optimal point is where the tail is still moving around while the cleaner is running, but not squirting water out of the pool too often. Hope that helps, Good luck!
Feb 25, 2012 | Hayward Phantom Pool Cleaner Complete with...
The phantom just goes around in circles & gets tangled until it stops.
It sounds like the gear box has failed inside the unit. Causing it to not go straight anymore. Replace the gear box assembly.
Apr 02, 2011 | Hayward Phantom Pool Cleaner Complete with...
My phantom spins in circles and goes upside down what could be my problem?
It is is going in circles, it is likely a bent hose. This is common with these pool cleaners if you store your hose in a coiled position. Try laying the hose out on a sunny day and leave it there a few hours to straighten the hose. The running on the side could be a result of the debris bag being too full and heavy. The pressure could also be too high, which would cause both of these problems. Try decreasing the water flow though your cleaner.
Sep 24, 2010 | Hayward Phantom Pool Cleaner Complete with...
Just spins around and around. It stays at the bottom and just spins in circles.
Hose problems are common with these pool cleaners, and this is likely your problem. The hoses have been redesigned, but if you have a model older than this season, you are likely having hose problems. You can either replace the hose or attempt to straighten it. Lay the hose out in the grass (slightly stretched) and let it sit in the sun for several hours. It should help remold any kinks or bends. Do not store the hose for this cleaner in a coiled position, since that will make the problem worse.
Aug 21, 2010 | Hayward Phantom Pool Cleaner Complete with...
The pool cleaner goes around in a circle
It could be that your pressure is too high through your cleaner or that you need to empty your debris bag. However, it is most likely a bend in your hose. Lay the hose out in the sun (flat and stretched slightly) and let it sit for several hours to undo any bends or kinks. This commonly happens with pool cleaners when you store them with the hoses coiled. If you are storing your cleaner like this, you should definitely stop.
Aug 14, 2010 | Hayward Phantom Pool Cleaner Complete with...
My Hayward Phantom pool cleaner has stopped cleaning and just goes in circles. How can I fix?
If the cleaner has no suction, check for obstructions in the debris chamber or throat of the cleaner. Also, check for hose leaks. If the cleaner has suction, but is just not moving properly and is spinning in circles, you most likely have a problem with your hose. It is a common problem with these pool cleaners getting small kinks or bends in their hoses that cause them to move in circles. If you store your cleaner hose in a coiled position, this will make the problem worse. Try laying the hose out in the sun and stretch it slightly. Let it sit for several hours, reconnect, and try it again.
May 27, 2010 | Hayward Phantom Pool Cleaner Complete with...
Need to know how to backwash the pool filter
Depends ...
There are two primary valve styles ... a "multi-port" and "push-pull". Never change a valve setting with the pump running.
Multiport has a handle that goes around in a circle (only move it clock-wise). You should go to your pool place to identify this kind of valve and get new lables. Push-pull goes up and down. Up is filter - Down is back wash.
If you will study your system, some things will become evident to you .
Your pump pulls water from the pool through the pump ... out of the pump into the filter. Through the filter, back to the pool. You might be heating the water (would be after the filter) and you may be adding sanitiser (after the heater). One suction - two discharges (oh, the other discharge is to waste.).
Recap ... water out of the pool into the pump - out of the pump throuth the control valve to the filter - out of the filter to the heater then to the sanitiser then back to the pool.
Any help?
Thanks for your interest in FixYa.com
BTW ... I am a volunteer question catcher at FixYa.com. At my job, among other things, I am a Certified Pool Operator (CPO), certified by the National Swimming Pool Foundation.
May 14, 2010 | Pool & Spa
Goes in circles
spin -out cam was stuck...freed cam
Jun 12, 2009 | Hayward Phantom Robot Cleaner without...
Hayward Phantom Robot Cleaner without Booster Pump Logo
388 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
