Question about Samsung 710V 17" LCD Monitor
Iron will not stayed turned on
My Black and Decker Iron is not quiet 2 yrs old and it will heat up but as I iron it turns off. I can shake the iron and get it to come back on but it does not stay on long enough for me to get anything ironed. Any suggestions?
Thanks,
    Scholar:
  • 42 Answers
Sounds like there may be a loose connection. If you are comfortable working on electrical appliances it should be something you can disassemble and find relatively easily.
Another possibility is that the thermal "fuse" is tripping and opening the circuit when the iron overheats internally. The fuse may be defective or the iron may be damaged.
Either way, in all honesty, I would just purchase a new iron as the potential danger is that it could overheat and melt down if fixed improperly :(
Posted on Mar 30, 2008
  • 286 Answers
What does this have to do with 17" LCD monitors?
It's an iron, throw it away and buy a new one.
Posted on Mar 27, 2008
SOURCE:
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
My iron won't turn on and if it does turn on it will shut off within seconds. Can you help with this issue? Black and Decker x420
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 21, 2010 | Black & Decker Quick N Easy X420 Iron
I have a black & decker iron model 6000 it wont heat up any more..its only 6 months old
It should be still under maufacturers warrenty? Take it back to where you bought it from.
Aug 01, 2009 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker model D1600 iron error message
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
I have a Black and Decker First Impressions (about 2 yrs old). When on steam it always spits out large puddles of water on the clothes as I'm ironing. It seems to come from the top or bottom part of the...
It's a possibility that you iron steam making elements are caked with lime and possibly the steam holes as well.
Purchase some "Lime Away" and dilute it 50/50 and pour it into your steam iron (drain all the old water out first and leave the iron unpluged) let sit for an hour or so and drain out, fill it again with clear water shake and drain out do this a couple of time then turn on the steam and see if it works properly, use the first time on an old towel to be sure all the chemical has been rinced out. Good Luck.
Feb 28, 2009 | Black & Decker D2030 Iron
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black and Decker AS775 Iron won't reset to heat up.
heatman101
May 22, 2008 | Black & Decker AS775 Iron
Iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Sep 17, 2007 | Black & Decker D2030 Iron
Samsung 710V 17" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
