Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
When pressing the slider switch on my 2003 jayco it just makes all the lights flicker and no slide
  • 6,674 Answers
You need to hook up a 12 volt battery, has this been done?
Posted on May 16, 2010
Hi, I have a 2009 Jayco Flight G2 29 ft travel trailer. Pls tell me where the slide motor is so i can hand crank the slide.
call any Jayco agent anywhere and they will be able to help you
google--Jayco caravans--- for an agent near where you are
Oct 17, 2017 | RVs
What would make my ipad just light and i can't get anything on it?
Try restarting your iPad. To do this, simply press and hold the Sleep/Wake button until a red slider appears; then slide the slider. To turn back on, press and hold the Sleep/Wake button until the Apple logo appears.
If tip above does not work, try resetting your iPad. To do this, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.
If above tips do not work, the issue could be that the battery is fully depleted. Plug it into a wall outlet for a while and see if your battery holds a charge. Please note that it can take up to 20 minutes of charging before the iPad will start up.
Nov 17, 2015 | Apple iPad Mini
Panel ligth and parking ligths is not turn on.
I have the same problem with my 1998 Grand Cherokee Laredo. I feel it has something to do with the slider switch. Pressing down on the switch while sliding it up and down and setting it at a desired level of intensity usually works for me.
Jan 03, 2014 | 1996 Jeep Grand Cherokee
MY NOKIA C2220 SLIDER PHONE SAYS ENTER RESTRICTION CODE WHEN I TURN IT ON ANYONE KNOW THE RESTRICTION CODE IT HAD A ROGERS SIM CARD BEFORE AND INM TRYING TO USE A SASKTEL ONE NOW
You can get the restriction code for your Nokia 2220 Slide ( C2220 slide ) from TheUnlockSpot.com by selecting the country & network to which your phone is locked and then provide the IMEI ( press *#06# to know ) when it is asked and get the unlock code through mail.
After you receive the code follow the method below,
1 - Switch on your Nokia 2220 Slide without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2220 Slide.
3 - Compose #pw+CODE+7#.
4 - The Nokia 2220 Slide would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly.
The letter w appears if you press the button star(*) four times quickly.
The symbol + appears if you press the button star(*) two times quickly.
Mar 10, 2013 | Cell Phones
How to adjust time, date and alarm
hi please specify ur brand name and model number of ur vacuum cleaner for a normal vacuum cleaner u can see a slider on the top slide the slider to the time and select the minute button and hours button to set the time and for setting the date slide the slider to the date and set the date using minutes button and for setting the alarm slide the slider to the alarm section and set the alarm on to off the alarm there are two options u can either press the snooze button which will stop the alarm for 5 minutes and after that it will ring ring again to permanently switch off ur alarm slide the slider to alarm off tab and press ok was this useful to u pls vote for me if u liked it
with warm regards - bonefirediv
Mar 25, 2011 | Vacuums
Sliding door light flickers on the dash board battery keeps dying
The door jab switch is bad,or the door is not shutting all the way.
Apr 25, 2010 | 2003 Toyota Sienna
Headlights and dash lights are flickering. Pleae help.
First check your baterry terminals, make sure they are clean and secure.
If it's your daytime running lights that flicker, check the DAYTIME RUNNING LAMP MODULE
If it's headlights, check the switch.
I hope this helps
Jun 01, 2009 | 2003 Dodge Durango
Lights flickering?
I have a 2003 PT Limited (not a GT) and have the same problem. I work for a Chrysler dealer and have had it in at least 4 times. They can't find anything wrong. Some blogs have said to make sure that the battery cables ar clean (did it). Ch the battery and replace (done). This is an irritating problem. Any other ideas?
Mar 17, 2009 | 2003 Chrysler PT Cruiser
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
179 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
