Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Four wires wrapped as two
I am installing a hunter thermostat and having a little bit of a problem determining how to label the wiring for the new faceplate. I took off the old thermostat only to find four wires wrapped as two connections. This is where I need help. The installation manual explains that if you have a two wire system then just hook it up to RH and W. I need to know if this is alright to hook up as a two wire installation. Since there's technically four wires which hook up should I install. Also they are unlabeled as to which wire is which. How do I go about determining what the wire is. Please help.
  • Hunter Master
  • 43,501 Answers
Yes...just keep the four wires wrapped as two and then hook up as a two wire connection...
The two wires wrapped together just makes it work better if the wires are a bit too light...
The two wires wrapped together will function as one wire...
heatman101
Posted on May 06, 2010
  • D. Floyd Kolb
    D. Floyd Kolb May 06, 2010
    Oh and it does not matter which is which on a two wire system you cannot hook it wrong..
How to turn hunter thermastat model 44134 on
This question needs to be reclassified with aftermarket programmable home thermostats--not fans.
Hunter 44134
Getting the wiring connections correct to the terminals in the back plate is essential. Understanding better which colored wires do what functions for your particular brand and model of HVAC gear proves essential, too: "That's the rub!"
Unlike the brilliant and wisely-instituted electrical code, a sensible common "code" for HVAC thermostat wires doesn't exist--each brand, and many models represented by such brands--may have their own peculiar wiring color conventions. HVAC techs also have noted the increasing numbers of brands and models in the market these days, as well--thus, they too may resort to online help threads concerning such issues. (Certainly, the wiring conventions for heat pumps differs also from that of a conventional heat/air setup.)
Unfortunately, many of Youtube's demonstrations from HVAC pros prove merely general info concerning HVAC systems--these may prove somewhat useful: Being merely general info, they're often not specific enough always for particular units, though. (This proves keenly true concerning thermostat wiring.)
Always switch off the circuit breaker for your HVAC system before proceeding with wiring. My system is a Goodman heat pump--it uses a five-wire thermostat setup: The 44134 model from Hunter doesn't feature a terminal in the back plate for the "C" wire for that. (The blue wire from my Goodman heat pump is the "Comm" or "C" wire--that's very confusing in it's own way--the "B" terminal on the back plate for the 44134, and most other programmable thermostats, often is used with B-coded wires for other manufacturers' HVAC units--generally, "B" wires for such units are blue, as well--beware of reliance upon wiring colors!)
Hunter's FAQs clearly indicate that the "C" wire connection isn't always necessary, nor appropriate, for their thermostats--their 44134 is one isn't an exception. I twisted on a small, gray wirenut onto end of my blue Comm wire, further securing that better with electrical tape. (Simply wrapping the Comm wire well with electrical tape should prove also sufficient.)
Unless you know your system's peculiar wiring very well (that is, you're likely an HVAC tech), don't try to connect a Comm wire to another terminal on the back plate for the 44134--you'll likely ruin your thermostat (perhaps along with some other HVAC electronics): You may need then to get an HVAC tech out, after all!
As indicated above, don't merely "match" wiring colors (as a woman might for interior decorating or remodeling)!: This proves a continuing and overly common, comical mistake! Prove instead somewhat skeptical of thermostat wiring colors! A Biblical scripture applies: "Be as wise as serpents!" Take your time to get wiring connections right!
I've noted that the 44134 unit relies totally upon 2 AA batteries (not supplied in the package)--those must be in good working order and oriented correctly--otherwise, your thermostat and HVAC system won't function. Furthermore, the control unit may be easily removed from the back plate--thus allowing "easy-chair" configuration--again, HVAC and fan functions will halt immediately--the connected unit proves necessary for continued function.
Hunter also points out (on their packaging as well) that the 44134 (and, many other (if not all) Hunter thermostats) won't work with baseboard heating systems. Hunter's site FAQs prove too sparse--some may prove keenly useful, nonetheless.
I can't yet get my heat pump system to work with Hunter's "always on" fan switch setting--the rightmost "Auto/On" setting for that bottom-mounted switch at the right. Perhaps a jumper wire proves necessary in the back plate terminals--somewhere. (I've noted this also for Hunter's common 44277 model, as well.) I glean perhaps that somehow invoking the "G" terminal proves necessary. As usual, investigation proves warranted.
Definitely note the "Cool, Off, Heat" switch on the bottom left of the unit: Yeah, that's all too easy to forget. The Hunter 44134 doesn't provide any feature allowing automatic switching between heating and cooling--one must choose which function for the thermostat to control. If the switch is set to "Heat," cooling isn't possible--and, vice-versa.
For reference and troubleshooting, keep the manual and install instructions in a safe, memorable, and easily accessible place. Hunter does provide PDF manual versions online--installation instructions prove lacking online though--they're not in the user manual, either. Unfortunately, Hunter doesn't upgrade it's PDF manual versions.
I glean that Honeywell units may prove generally more easily configurable than Hunter units. Nonetheless, configuring Hunter units proves far from impossible, though. Configuring Hunter thermostats prove perhaps not as "intuitive.": The formal user manuals provided by Hunter thus may prove more keenly necessary for their thermostats' configuration.
Getting personal help online from Hunter may prove somewhat difficult (that may have changed recently). A few years ago, I called customer support: A woman answered my wiring question very satisfactorily. (I noted a jumper wire connect to the terminals of my old manual thermostat--she indicated that the jumper proves unnecessary in Hunter units.) Hunter phone support hours prove somewhat limited--they're similar to traditional office hours.
As with most programmable thermostats, the Hunter is a PRC (Chinese)-fabricated general-purpose consumer circuitry device. As such, it's (overly) intended to be wired and configured by the user to provide correct function for many particular and compatible HVAC brands/models. Given the particular installation that may perhaps prove difficult. Given the general-purpose nature of such thermostats, a simple installation sheet of instructions can't always offer sufficient and correct answers.
Without the particulars of your HVAC system and thermostat wiring, it proves very difficult in some cases for Fixya and other DIY sites to provide correct answers. (Most DIYers ultimately do succeed with install and use of programmable thermostats, though.)
"Proust" thanks you for getting this far!: Perhaps some of my particular solutions here do prove useful to some of you--more nit-picking, detailed work and anecdotes (intended for specific brands and models) needs to be offered in this area....
Mar 17, 2013 | Dryers
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
The Honeywell LR69071 (old) has 7 wires connected labeled (X W2 R O Y G E) The Hunter 44860 (new) has wire connections for ( Y1 Y2 W2 G RH RC/R B W1 E O C L) What connects with what? There is also a jumper...
Wiring on the old one, "X", probably a brown wire will not be used on the new stat. If it's a blue wire, this may be your common. "E" and "W2" probably wired together with a white wire, this controls electric heat. "R" with a red wire, this is 24 volt power. "O" is an orange wire, this is the reversing valve. "Y" is a yellow wire, this is the contactor. "G" is a green wire, this is the blower. This pretty accurate? On the new stat, the jumper should be connecting "RH" to "RC/R", leave it in and wire the "R" from your old one to either terminal. White from the old one will go to the "E" of the new one. If your electric heat doesn't work after the install, you may need to jumper the "W1" and "W2" with the "E". "O" wires to "O". "Y" from the old one wires to the "Y1" of the new. "G" wires to "G". "C" on the new one is common. Usually a blue wire goes here. If "X" on the old one was blue, plug it into the "C". If it was brown, I'd suggest not using a common, and installing batteries. Hope this helps.
May 03, 2010 | Hunter Fan Company 7-day programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
520 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
