Question about Garmin StreetPilot c340 GPS Receiver
Can't get unit to source home . - Garmin StreetPilot c340 GPS Receiver
    President:
  • 1,851 Answers
Source home is not a term that is associated with GPS in the way you're trying to use it.
The way to go HOME is to first SAVE your HOME ADDRESS and then - click WHERE to - then Favorites and then HOME
Posted on May 06, 2010
Speakers on cinema surround sound working on test only
More than likely the optical connection is defaulting to another source. The optical may have been intentionally assigned to another source and either needs to be reassigned or try switching the inputs on the unit until you hear sound...
Feb 04, 2014 | Logitech Z-5500 Audio Subwoofer Thx...
C00f0401 error code power on or off
Hi
The 'turn power off then back on' error is generally indicates a problem with the power source. I suggest you move the PSC to another power source. If the problem persists there may be an issue with the power module on the unit. You can return it, test it there. It ther problem is also present exchange the unit for another. You may want to test it at the store before heading home.
May 11, 2011 | HP Office Equipment & Supplies
Need to no how to hook up sony equalizer SEQ9 to rca rt2760 home theatre reciever
First of all, any analog sound processor employed with a multichannel receiver will on;y function correctly for analog 2-channel sources. Second, it needs an opening in the audio path that allows it to get between the source and the amplifiers, commonly know as a Tape Monitor loop. There would be a Line Out and a corresponding selectable Line In that does not disable any other source. That way a seelcted source like FM would exit the unit, be processed, and come back IN for listening.
This receiver doesn't have that.
You COULD place the EQ between an external source and Line In if you want to Equalize one source for playback.
Apr 19, 2011 | RCA RT2760 System
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I have a magnivox home theater model #mrd510 all my speekers quit working on the unit , how do i fix it ive reset the unit , checked to see, it is not on mute! i have also checked the speakers, its the...
Check the source cable is ok, replace with another if possible.
Also make sure the source is not putting out a standard the HTS does not understand (ie DTS or PCM).
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Philips Magnavox MRD510/17 Theater System
How do I get tv audio to play on the home theater system
This HTS isn't really designed to be a versatile processing center for external sources.
My advice is to treat TV-related audio as any other audio component. First, its best source will be the first device that processes it - cable box, sat box, gamebox, BD etc.
I'd also bypass this unit's video connections for those video sources and run them directly to your TV or monitor. The best unit for each function (audio or video) should get the best source directly.
Get the best-quality digital audio that unit will provide and run it into the HTS. This HTS has one optical (TOSLINK) digital input, so THAT would be where the best digital audio would enter it. Hopefully, your source uses optical audio output. Otherwise... analog audio is limited to stereo or derived Dolby Surround.
Sorry.
Dec 23, 2010 | Samsung HTC550 Theater System
Connected Samsung Home theatre HT-Z320 to my new sony lcd. No sound, can anyone help
Check connections.
Make sure you are on the correct Input/Source, adjust volume acordingly.
Please give details about what sources and connections you are using.
Dec 27, 2009 | Samsung HT-Q100 System
Dynex and Samsung
A common problem with these "all in one units"
When you have a DVD playing it is a digital signal direct to the processor.
When you have an external source ie: TV etc it may be a digital source, but you have to tell the Samsung unit this.
Make sure when it is on the TV setting (Aux) or whatever input you have chosen is in Dolby Digital or similar, Not stereo.
The unit should have a setting for this called sound program or sound setting.
Jun 13, 2009 | Audio Players & Recorders
Cannot get sound from tv to surround sound speakers
you will need to connenct audio cables red and white from audio out on tv or from programming source(cable box sat box) to the audio in on back of jvc unit. then set unit to appropiate source (where you connect cables on back of unit it will be labaled and remote will have button to get to that connection labeled the same) if you want to get digital sound you will need and digital coaxial or fiber optical cable from source(cable box or sat box) and then set unit to video 1 for coaxial and video 2 for optical
Oct 22, 2008 | JVC THD-50 System
Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Dec 03, 2007 | Sony HOME THEATER SYSTEM System
Garmin StreetPilot c340 GPS Receiver Logo
101 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
