Question about Roper REX4634KQ Electric Dryer
Turns off during cycle
Our dryer appears to be overheating and turning itself off during the cycle, it then will not start for awhile. We have taken the back off and thoroughly cleaned the vent. Is there possibly a thermostat or something else that would be turning it off? Thanks
    Problem Solver:
  • 8 Answers
Motor is getting hot and shutting down. Probably have to replace motor or clean it.
Posted on Mar 27, 2008
SOURCE:
My lg dle4801w turns on then turns off and wont turn back on to dry the clothes
will it start after it sits awhile?if the dryer starts and then turns off and won't start right up again you could have a bad motor,after it cools down the motor can reset and will run again,the dryer might be clogged with lint overheating the motor but if you write back with more info it would help me to help you,this is just one thing it could be..
Jan 06, 2018 | LG Dryers
Washer turns off during wash cycle for no reason
Motor probably overheating. How old is it?
Dec 01, 2013 | Washing Machines
How to tell if dryer motor is bad
if some of the parts of the bearing get broken then it will hard to run,how about the starting capacitor did you already checked.
Aug 11, 2012 | Kenmore Dryers
My dryer takes forever to dry anything and often times will not turn on when i press start after it's been ran for a 70 minute cycle but will turn itself on after sitting for awhile my dryer is
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 14, 2012 | Whirlpool Dryers
I have a GE Dryer DBVH520. While drying clothes, it turns off for a couple of minutes and then turns back on by itself. Sometimes a couple times during a drying cycle. Is this normal?
The short verision is you most likely have a short on the dryer start switch OR a bad control board if there is no start switch at all. Both are very repairable items and something you could also do yourself if you wish... If you need help ordering a part feel free to call me Greg at 402 228 3302 and I can look it up for you.
thanks!!
Greg the Maytag Man at Daubendiek TV
Sep 30, 2010 | Dryers
Shuts off too soon when the clothes are still wet
Make sure the door does not come open while running.
If it turns off only during the auto-drying cycle, the moisture sensor may have failed.
If it turns off during the timed cycle, the operating thermostat has most likely failed and the high limit thermostat turns the machine off when it gets too hot. After the machine cools down, it will start until it heats up and turns off again.
Apr 29, 2010 | GE DWSR483EBWW Electric Dryer
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
What goes on in the dryer as it is being used?
customer selects cycle
customer pushes start button
motor starts, motor switch closes and turns on element or igniter
depending if electric or gas
tub turns and heat dries clothes
thermastats cycle during run not to overheat clothes
timer cycle ends
you get clothes out now dry and put on
Apr 19, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
178 people viewed this question
Top Roper Dryers Experts
Marvin
Marvin
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Roper Dryer Expert? Answer questions, earn points and help others
