Question about HP Pavilion tx2500z Notebook
WHAT CAUSES SWIVEL TO CUT POWER ON TABLET
WHAT WOULD MAKE HP TX2510US LOOSE POWER WHEN I ROTATE SCREEN I GET ABOUT HALF WAY AROUND AND IT SHUTS OFF WHAT PART DO I NEED TO FIX THIS IS IT EASY TO FIX
  • 54 Answers
There can be various things, it can be the LCD connector, or the pin of the power port or the ac adapter (charger) as well!.. best way to find out is call up the tech support no.--18004746836.
Posted on May 06, 2010
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
Jan 25, 2015 | HP Tablets & eReaders
Half the display panel is black on rca tv, if i tap the tv it comes back on. could it be a short in the wiring? i need a wiring diagram for a l42fhd37r model
It is most likely a loose ribbon cable from the TCON board to the flat panel itself. They commonly come loose when the TV is on a swivel stand and is moved frequently. This is because the swivel motion often causes a slight twisting of the LCD frame and this works the ribbon cables loose.
Jan 25, 2015 | RCA Televison & Video
Pavilion tx2510us video upgrade
You can't, usually. It is an integral part of the motherboard.
Dec 15, 2013 | HP Pavilion tx2510us Tablet PC AMD Turion...
Touch pad not responding
are their any driver discs with the item? try re installing them as all components such as keypad etc have drivers. other than that its a hardware issue and needs repair.
Jan 20, 2011 | HP Pavilion tx2510us Tablet PC AMD Turion...
HP pavilion tx 2130 screen becoming loose on hinge, in open/close movement. (swivel function unaffected)
In the screen section after remove the front plastic around the LCD you will see some screws holding the LCD display in place. Sometimes these get loose over time. If you can locate and remove the screws " usually under little pads or stickers " and pull off the plastic case around the LCD screen " usually held on by some clips as well " you will easily have access to the hinge screws from there just tighten them down and make sure there no broken off the housing for the screen. Then place the front panel back on and screw is back on and you should be good to go again,
May 08, 2010 | Computers & Internet
. screen orientation not working
what exactly is it, is it you screen which is rotated, if it is i would suggest you should go to control panel, nvidea control. there should be a menu on the side, in the section display there will be rotate screen, you can adjust your rotation there or any other screen settings, hope this does solve your problem.
Sep 13, 2009 | HP Pavilion tx2510us Tablet PC AMD Turion...
I am afraid do that , and i am see new thing i am see when it problem is show , i am see 2 small limps , is light and hide , it's one between the Caps lock and the another up the end Button
Ya qusay,
I tried to get a picture of your keyboard but could not get one clear enough.
Your laptop is a Tablet PC:
1.You can use the keyboard to type documents;
2. you can also use a stylus.to write.
3. You can rotate the screen and hold the computer on your left arm( as you do a slate) and write with the stylus on the screen.
4. Probably it has a touch sensitive screen.
I suggest that you take the time to learn to use it, starting with the manual that was shipped with it. It will be rewarding.
Hope it encourages you to discover the special qualities of your Tablet PC.
Aug 30, 2009 | HP Pavilion TX2510US Notebook
Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge.  Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
Apr 30, 2009 | Toshiba Satellite R15-S822 Tablet PC
Startup/shutdown
Sounds like a failing hard drive.
Have you got an XP or Vista cd around?
Feb 25, 2009 | HP Pavilion TX2510US Notebook
Screen loose
Open your laptop case(Not LCD case) & see the mechanical portion is damaged. IF possible change this parts by byeing secondhand parts from scrap area/ put some synthetic(Do not use petrolium gum) gum & plastic & finish it properly. I think IF you can make it properly it could solve your problem.
Feb 05, 2008 | IBM ThinkPad X41 Tablet PC
HP Pavilion tx2500z Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
