Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Clean Light blinks, wash cycle does not initiate
At one point, possibly due to a power failure/spike in the house, the Control Lock was activated and the Clean light/indicator repeatedly blinks @ 8 flashes per cycle. It took over 8 seconds (as opposed to the 4 seconds) to unlock the control. However, I have found no way to override the blinking Clean light/indicator.
Consequently, the wash system does not come on.
Any cogent technical support that remedies this problem is greatly appreciated. Thank you
    President:
  • 949 Answers
The clean light usually will blink due to a failure to heat the water properly. I have put together some information on this and how to reset the machine so it will work again. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 06, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why doesn't it work?
Replacement parts could be defective, though new.
Jan 28, 2016 | Washing Machines
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Possible Control Board Failure
This washer can be a pain to diagnose. Diagnostic document link. www.pwslaundry.com%2Ffiles%2Fdocs%2Fmaytag-whirlpool%2FTech-Sheet-W10280489-Rev-D.pdf&ei=K_JCU-yhK4Sh2AWIzYCQBA&usg=AFQjCNFDvmjAg2YHolMCS_ZHhzuw0_lb3w&sig2=OxlosNGyV7nkO4Rc48PNpw&bvm=bv.64367178,d.b2I&cad=rja
Follow the diagnostic directions. The first suspect part would be the mode shifter. Next I would suspect the main control board. All the testing info you need is in the service manual. Check/Ohm out the shifter first.
Apr 07, 2014 | Maytag MVWC300XW Washer
My whirlpool whitemagic washing machine top panel board doesnt work or no power?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If there is no power check the outlet and mains wire. If not the control board is a suspect., check the door switch which needs to close for the program to activate.
Feb 28, 2013 | Washing Machines
Program light and power light blinking
Jan 20, 2013 | Washing Machines
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Washing cycle cuts out I noticed "power cut" on
It sounds like you may have a loose connection somewhere and you are loosing power to the machine, worst case scenario there an issue with the motor controller module.
I dont understand the door flop down, these should lock unless of course the motor locking unit is buggered causing the system to restart.
Jun 06, 2011 | Fisher and Paykel IWL12 Top Load Washer
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Why won't door latch lock?
The lock is activated by the control board / timer at specific times to prevent opening of the door (like when the tub is filled with water during the wash cycle and during the high speed spin cycle). The electrical or mechanical part of the lock may have failed or the portion of the control board that energizes the lock may have failed.
If it is just the lock, it may be a relatively easy fix - but it is always possible that the failure of the lock also caused the subsequent failure of the control board too (that's just Murphy's Law) . A control board replacement in these machines typically is not overly difficult job; but you may find the board itself may be a fairly expensive part.
I hope this helps
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
325 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
