Question about Dell 962 Photo All-In-One InkJet Printer
Dell 926 printer
This is my second dell 926 printer. It refuses to communicate with the computer. I thought the first one was defective. Help!! I have purchased a new usb cord and everything!!
  • Anonymous Mar 12, 2014
    Dell 926 printer skips
    Novelist:
  • 141 Answers
Go to Dell Journal ID: 08086MJJNF
Article ID: 316455
Date Published 1/4/2008
Last Revised: 3/25/2008
Go to www.dell.com and top right type in 926 printer; it will bring you to the next page, click on the first result: Install Dell 926 All-In-One Priter Drivers. This should help you. Follow all the directions exactly!
***Did you uninstall the first 926 driver before you did anything else. You must uninstall the first driver and install the driver for the second 926 printer.******
Posted on Mar 26, 2008
Printer cannot communicate with computer
look in the sticker of product /model/ maker. then go to the website and search for the driver. download it. when installing the driver it will ask to plug in the printer wire usb cable from printer into computer to complete process.. sometimes the manual of printer show a procedure of menu keys to set up printer to pc to calibrate printer. .
in control panel. search for devices and printers. look for the printer when located. try a print out.give it a test. good luck
Jan 03, 2014 | Dell 926 Photo-926 All-In-One Printer 926...
Reset my Dell 926 all in one printer
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
    • 2
      Disconnect the USB connector cable for the printer from the computer.
    • 3
      Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
    • 4
      Plug the USB connector cable back into a USB port on the computer.
    • 5
      Plug the power cord for the printer back into power strip or electrical outlet.
    • 6
      Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Oct 22, 2011 | Dell Photo 926 All-in-One Printer
A notification pops up saying your printer does not communicate with your computer.
A communication issue likely has to do with the drivers.
How to Download and Install the Drivers for a Dell™ 926 All-In-One Printer
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&docid=266098&doclang=en&l=en&s=dhs
Trust this is helpful. :)
Dec 09, 2010 | Dell 926 All-In-One InkJet Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Ink from wal-mart
Like any other product, there will sometimes be defective cartridges. Take the one back your printer is complaining about back to Wal-Mart and exchange it as defective. They'll just send it back to the manufacturer. (Sometimes it's easy to overlook the possibility a new part is bad. It's a real pain when that happens, but it does.)
Apr 07, 2009 | Dell 926 All-In-One InkJet Printer
Communication Error DELL 926 AIO Printer
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Jan 16, 2009 | Dell A920 InkJet Printer
Dell photo 926 printer communication problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Oct 05, 2008 | Dell 926 All-In-One InkJet Printer
Can't print
Step 1. Go to Control Panel--Windows updates; click Check for Updates--Windows is sending updates for different printers. If there is one install it. See if that takes care of the problem.
If not, go to Step 2.
Step 2.---Turn on the Printer---go to Control Panel---Device Manager. Under device manager look for any yellow exclamation point, if there are any under "Imaging device" or Portable Devices, then there is something wrong with the driver. Go to www.dell.com at the top type in 926 printer, the next page click on the first result "Install Dell 926 All-In-One Printer Drivers. Follow the directions one by one, start with the first and work your way down.
Also,
There is a firmware update release 1/6/2008 for the Dell 926
Go to www.dell.com home page. Go to Support and Help in the middle of the screen, put the cursor over it and click Drivers and Downloads; next screen identify your model: Select Model-Printer; select you product line--click on Printer; next page Select you Product Model 926 (Personal All-In-One) click on it;
then confirm Under Printers click the plus sign and it will give you 4 options, choose the firmware option. DO NOT INSTALL THIS FIRMWARE UNDER YOU HAVE TRIED EVERYTHING ELSE. SOMETIMES FIRMWARE CAN MAKE DEVICES INOPERABLE.
GOOD LUCK.
Mar 26, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
373 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
