Question about Craftsman Garden
Craftman pressure washer throttle linkage
I have a crafstman model 580.752600, serial number 1005587996 2,600 psi 2.5 gpm pressure washer with a 7.0Hp intek briggs and stratton engine. I rebuilt the engine because it broke a connecting rod. I now however cannot figure out how the trottle and governor linkage go on.I was wondering if you could supply a description or a diagram. Thanks Jon.
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
SOURCE: I do like to know if this washer is good enough
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Posted on Oct 20, 2010
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
I have a new model 020486 pressure washer and as soon as ithe engine starts it runs at full power and keeps on running at full throttle and does not idle down. any help out there? thanks
Check the Gov. linkage to make sure it`s moving freely and note if shaft on side of engine may need adjustment.
if so loosen up crimp bolt (Caution Gov. shaft can slide in to engine and need to be disassembled to be recovered ) turning C C and making sure throttle shaft is closed tighten bolt.NOTE, Some B&S engines are C W Adj. as well
May 31, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
Troy bilt pressure washer will not build or reach high pressure
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Where X = a number.
Aug 31, 2009 | Briggs & Stratton Garden
No pressure
Replace the bypass valve, this is the most common problem. Failing that remove high & low pressure valves and ensure they are not blocked or worn
Aug 06, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
257 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
