Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Hi i have a briggs engine with a pusla jet carb when i pussh the prime bulb fuel dosnt enter the carb the bulb is fine engine dosnt start icleaned everthing with carb cleaner any ideas thanks
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
My Briggs & Stratton 450 Series Lawn Mower Engine starts after priming but stops almost immediately as if it is not getting fuel
The primary jet is probably clogged. If you remove the fuel bowl and float assembly you should be able to slide a fine wire through the orifice to clean it. Rinse everything with carb cleaner before reassembly.
Jun 22, 2014 | Husqvarna 450 e-series 18" Chain Saw
Briggs and Stratton 10T500 engine will run on prime fuel only. Carb not supplying fuel. Small carb tube that dips down into fuel tank seems unobstructed. Tank full of new fuel. Exhaust muffler is...
make sure that the inline fuel filter is clean and thenremove carbeurettor make sure all the jets are clean then reset the idle jet to 1.5 turns from closed, replace everything bada bing bada boom shell run like a champ.
Oct 27, 2017 | Briggs & Stratton Garden
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
How do I fix my push mower with a Briggs & Stratton engine?
Its obviously a fuel starvation issue, so there is still some blockage in the carb, re move the carb and see if your frendly local dealer will clean it in there sonic cleaning tank, if not soak with carb cleaner and blow the jets through.
May 11, 2012 | Garden
Lawn mower starts but makes a put put sound and runs for only 5-10 seconds i have cleaned carb bowl replaced fuel line replaced priming bulb and replaced air filter
I hope this helps you. :
http://www.fixya.com/support/r8367428-starts_dies_common_engine_problem
I would recommend using carburetor cleaner and flush out the jets.
Joe
Mar 23, 2011 | Briggs & Stratton Briggs Stratton...
Briggs & Stratton Poulon Pro 600 Series Cuts Out After a Min
Water in the carb bowl. Primer charge is gas...what the main jet draws is water! Tipping backwards lets the water move away from main jet pickup and clean fuel to enter engine.
Drain the tank. Then the carb and fuel line. Then check your gas can for watery fuel. *(dump it into a large plastic bowl and look to see if there is a layer of water on the bottom. If you shake up the fuel before you pour it off you will see cloudy liquid if there is water in it).
That should do it.
Jul 17, 2010 | Briggs & Stratton Garden
Gas Push Mower - Briggs & Stratton, will start but run for
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Sep 29, 2009 | Garden
Must keep pushing primer bulb to keep mower running, need manual
The main suction jet in your carb. is blocked.Remove the bowl and push a thin needle up the centre jet in the carb and blow the jet out with compressed air. Stephen.
Sep 22, 2009 | Briggs & Stratton Garden
My Yard Machine W/a 6hp B&Sengine will crank & run on starting fl
Most likely you still have a jet inside carburetor that is clogged how did you clean it soak it in carburetor cleaner? Did you take out jets to make sure they are clean
May 05, 2009 | Briggs & Stratton 66set Panzer Tractor...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
117 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
