Question about Nokia E72 Smartphone
I have Nokia E72, how can I connect to VOIP service in our office?
  • 560 Answers
Go to Tools > Settings > Connection > SIP settings
Profile name: any
Service Profile: IETF
Default Access point: select your access point
Public user name: sip:your-voip-ext@voip-server.com
Use compression: No
Registration: select your preference
Use security: No
Proxy server: empty/no settings
Registrar server:
> Registrar server address: sip:voip-server.com
> Realm: asterisk
> Username: voip-ext-no.
> Password: voip-password
> Transport type: Auto
> Port: 5060
Then go back to Connection > Internet Tel.
create profile and select the SIP settings you just created.
Posted on May 10, 2010
  • Liza Halbrook
    Liza Halbrook May 13, 2010
    The setting is also tested and working on Nokia N82, E71, E61i and E63.
Sir my phone is nokia E72 has locked
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Mar 18, 2017 | Nokia Cell Phones
I forgot unlock code for my nokia E72, my IMEI no is 357895042280596
Oct 22, 2012 | Nokia E72 Smartphone
How can I use my Nokia E72 Mobile as WebCam connecting with my PC with USB port or Bluetooth?
Aug 11, 2011 | Nokia E72 Smartphone
E72 imei Code 351513041736015 i need master code
Default 6 Digit Security code: 000999 or 1122
OR:
Jul 31, 2011 | Nokia E72 Smartphone
I forgot Unlock Code for my Nokia E72
Default 6 Digit Security code: 1122 or 000999
Oct 05, 2010 | Nokia E72 Smartphone
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
I have a Nokia E72 with WLAN as a built-in feature. How do I use this feature?
Whenever I disconnect the E72 WLAN (already in connected WLAN mode), E72 will reconnect WLAN again automatically within 1 second.
MANUAL
http://europe.nokia.com/find-products/devices/nokia-e72/specifications
Feb 26, 2010 | Nokia E72 Smartphone
Nokia E72 Smartphone Logo
778 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
