Question about Whirlpool GBD307PDS Electric Double Oven
Throwing the breaker .had the oven for 6 weeks working fine now turned on the upper oven and the breaker threw. the house/wirting is only 10 years old?
  • Whirlpool Master
  • 43,501 Answers
You have a problem in the oven not in the house wiring...you probably have a bad element in that oven and it is shorted...this throws that breaker when you turn it on...
heatman101
Posted on May 06, 2010
Range throws an F5E1 code, cleaned the oven 2 weeks ago. Worked fine. Plugged it back in today to clean oven but it threw the code, door is not locked.this is in a rent house.
Using the 'self clean' function nearly always results in faults. We see it here all the time, burnt out elements, doors that won't open, fires and error codes. Google the manual for it. They are all online
make model manual
The error is listed in this link. Also look at the video tab
whirlpool f5e1 error code Google Search
Door latch problem
Whirlpool Super Capacity 465 E1 F5
Apr 09, 2018 | Ovens
Bosch hbn7052gb oven trips circuit breaker
That is interesting because the major current draw of your oven will be during startup and warm up. I think I would replace the circuit breaker. As your oven warms, your breaker could be heating up and pops at about 150C.
Might not be the issue but a reasonably cheap place to start.
Good luck
Semper Fi,
Z
Feb 16, 2018 | Ovens
We have a Kitchen Aid Electric stove about 10 years old and there was no owners manual left from the last owner. This week we turned on the oven and there is no heat from the elements on both the bake and...
The first thing I would check is the breaker for the oven at the breaker box. I have encountered similar problems and a partially thrown breaker ( or one pole of a double-pole breaker) can cause this. Find your "range breaker" in your breaker box and cut it off then flip it back on. There is a good chance that might fix your breaker. If it is an older house with fuses, then the range would be on two fuses and one of them is blown. This happens to dryers also (if the right fuse/breaker goes, the motor runs but it won't heat)
Hope this helps
Jan 28, 2011 | KitchenAid Ovens
This cooker was fitted by Kitchens Direct last year, so is new. No manual was left by the fitters A power cut, throws the electronics out and the oven stops working. How do I get the light to stop...
Most likely, the digital panel just kind of locked up. The first thing I would try is to turn off the circuit breaker at your home's breaker (or fuse) panel for about 5 minutes and then turn it back on again. This should "reboot" it and hopefully the oven will get its brains back!
I hope this helps! :)
Dec 14, 2010 | Ovens
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Oven won't turn off!
it probably needed to reset computer/electroics
but i would call customer service for the brand it is a dangerous thing to play with.
make sure there were no recalls also.
Apr 05, 2017 | Maytag CWE5800A Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
77 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
