Question about Kenmore 24 in. 15689 Built-in Dishwasher
Not draining properly
I tried to use my dishwasher and it started bubbling onto the floor, the water won't drain properly and now the water is just sitting in the bottom of the machine.
    President:
  • 1,902 Answers
Check for plugged drain hoses in your dishwasher, also make sure that the pump is working correctly
Posted on May 06, 2010
What would cause the inside of dishwasher to slowly fill with water even in off position.the water drains just fine, but after drained it will slowly start filling the bottom of dishwasher back up.
the water control solenoid unit has a faulty diaphragm in it allowing water to pass even though the power is off
replace it or turn the tap off after each use
call a technician for the proper diagnosis and repair
Jan 28, 2017 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Water wont drain every time
Hello
When a dishwasher won't drain, that usually means that the appliance's drain line is clogged. The drain line, which connects the dishwasher to the garbage disposal, must be cleared of debris before the dishwasher will resume its normal operation. If the drain line is the problem, clearing it is simple and requires only a few standard household products.
Turn off the power to the dishwasher, if possible. Remove all the dishes and the racks. Put on a pair of rubber gloves and use towels to soak up most of the standing water in the bottom of the dishwasher.
Unscrew the rotating sprayer arm in the bottom of the dishwasher. Rinse off the arm and all its seals and screws in the sink and set it aside.
Locate the filter screen in the back of the dishwasher's floor. Pop off the screen, using a screwdriver to loosen any bolts that may be holding it in place. Rinse off the screen, then wipe the dishwasher floor with paper towels to remove any large pieces of food or other debris. Wipe the area clean with a damp sponge.
Replace the screen and the sprayer arm. Locate the drain line; it should be near the back of the floor of the dishwasher, right underneath the filter screen. Pour 1/2 cup baking soda into a cup and add enough water to make it into a pourable paste. Pour the paste into the drain line through the screen. Add 1/2 cup vinegar to the drain line and let the solution fizz for 15 minutes.
Boil a quart of water. Remove the pot from the heat, allow the bubbling to subside and pour the water into the drain line to clear the baking soda solution. Watch the water go down the tube; if it seems to be draining slowly or not at all, repeat the baking soda treatment.
Replace the racks and make sure that everything is put back together properly. Turn the power back on and run the empty dishwasher through one normal cycle to see if the drainage problem is fixed. If not, repeat the process a few more times. If the issue still isn't resolved, the problem may be with the pump or another electronic part. A professional is best suited to deal with an issue like that.
Sep 07, 2011 | Dishwashers
The water wont drain from our whirlpool slimline, and the tablet will not come out and wash the dishes
Hello
Aug 09, 2011 | Dishwashers
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
My dishwasher has water on the bottom that wont drain. I poured some Draino on the bottom but it didn't work. So I tried to run it (without dishes in it) and bubbles and water came out onto my kitchen...
**** out the water with a wet vacuum machine. Remove the sump guard and check with you fingers for any obstacles that prevent the draining. **** out the water and anything else from there. Put the guards back.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water won't go out of the dishwasher
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
Apr 09, 2009 | Dishwashers
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Kenmore 24 in. 15689 Built-in Dishwasher Logo
136 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
