Question about Pitco Frialator SG14 Deep Fryer
Burner Welds I have been using Keating Fryers for years but the burner tube welds keep cracking and releasing shortning (there are shields that are supposed to keep some of the heat away from the welds but they don't solve the problem). I have replaced many fry "pots." Do Pitco Fryalators have a better tube design and how often can I expect to replace the fryer pot (vessel) because burner tube welds break? Joe
You have your burners misaligned with the tubes. Re-align the burners and the welds will hold up fine.
Posted on Jun 19, 2008
  • Gustavo Hernandez
    Gustavo Hernandez May 12, 2014
    I want to become a certified welder like my father, the only problem is, I am less than adequate at it right now. I am however, undeterred in my mission to become a qualified fabrication welder. You guys all inspire me in mission thank you. Gustavo Hernandez |
Burner tubes clog up w/carbon daily and sparks are coming from the rear exhaust port
air fuel mix to burner not wright
check burner for holes
check injectors are clean
check burner air inlet is clean
check for low gas pressure to machine
Jan 10, 2016 | Kitchen Appliances - Others
Repair crack in floor of acrylic shower
Hello their is a product called Plasweld,it comes in a handy tube,
Carefully scratch along the crack to allow the weld to come flush with the surface of the shower tray,MUST BE PERFECTLY DRY!
squeeze into the crack and it will find its own level ,this produce actually welds the plastic together
Good builders merchants should stock this item.GOOD LUCK
Sep 03, 2014 | American Standard Home
I have an old Tec Searmaster II 1 burner. The burner (screen) got a long crack line and the burner shield got some holes. When I open the grill, I heard a pop noise and some fires are up. Should I change...
Some parts are still available for your discontinued model Tec Grill. The burner less the screen varies in price from $329.00 to $399.00. The Heat Plates start at $153.99. For more information go to
Hope this helps you.
Jul 03, 2011 | Tec RadiantWave Grill
What are most common problems found with pitco frialator fryers?
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
Feb 09, 2011 | Pitco Frialator SG14 Deep Fryer
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
It could a heat shield on the exhaust system. The heat shields are spot welded on to the exhaust pipe and as time goes by the welds break. Now, instead of the shield being welded in a couple places to secure it it's being held on by one or two welds and it rattles from time to time. I could be wrong, good luck.
Mar 27, 2010 | 2002 Chevrolet Suburban
Loose heat shield
Most likely it's a heat sheild on the converter, maybe the muffler. 1 on top and 1 on the bottom. The heat sheild is welded to the converter, over time they rust away, around the welds. You can use a large diameter worm gear clamp to keep the heat sheild from rattling. The sheilds are in place so if you drive over grass, the heat from the converter won't ignite the grass.
Mar 14, 2010 | 1997 Honda Accord
Main burner too hot & 2nd burner pilot won't
Set t/stat to 250 degrees. If it does not shut off after about 5 minutes, replace t/stat.If shuts off, must be calibrated Pilot may be dirty, flame weak. If flame strong, replace thermopile(pilot generator). If weak, must remove and clean pilot orifice inside pilot.
Aug 29, 2009 | Keating Kitchen Appliances - Others
Dean gas deep fryer burner on high will not respond to temp set
The thermostat is likely welded shut. You'll have to change it out.
Feb 25, 2009 | Dean SR14E Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
133 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
