Am having difficulty connecting through modem I had the system working up until about two weeks ago. I was trying to access the wireless router with another computer and was prompted to enter the 8 digit pin found on the router . I did that and I believe my network name was changed and I was unable to connect to internet through the router and the modem. I can connect if the modem is hardwired to the computer, but not through the router. I am getting a a blinking orange modem light on the router when the the router and the modem are connected. any ideas?
    Guru:
  • 163 Answers
Ur wireless router is not configured for the wireless lan.Don't worry here is the solution for the problem......
Open Internet Explorer. In it enter the ip address of the wireless router.. Enter the username and password Then go to wireless option and select the security type as wep and provide a network key that will be ur connecting password... That's all
Now when u r connecting to wireless select the network and provide the network key that u have given...
Posted on May 06, 2010
I installed my D-Link DI-784 six days ago. It's connected to a Dell 8100 running Windows 7. It worked fine until an hour ago, when it stopped broadcasting. The router is connected to a DSL modem. If...
It is possible that a neighbor purchased a wireless access point that it on the same channel and they are competing. Change your wireless channel. You could also try a hard reset. Instructions at D-Link's website. Good luck!
Apr 08, 2011 | D-Link (DI-784) Wireless Router
Can only get internet access on main computer. Cannot get access on wireless or second computer. This worked until 2 days ago. I have checked all the connections and have tried to reset the router (I...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Oct 24, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
Slow internet connection westell e90-610030-06 dsl modem. was pretty fast 2 weeks ago thanks phil
try to do the ff:
power cycle modem/router
check router security settings
check for wifi barriers
delete previous wireless connections
optimize ie
If your wireless connection is working fine 2 wks ago then you may also try to run system restore
Mar 28, 2010 | Westell Wirespeed LiteLine 6110 Modem
I got Embarq DSL a few weeks ago, i can get online for a minutes then the internet will go out, i have to reboot the modem several times before it will come back up, ive tried changing where the modem and...
If Embarq cannot or willnot help you, drop them and get another service.
First connect your modem directly to the computer to isolate the problem. If it solves problem then difficulty is in the router. Then contact the router manufacturer.
If problem persists the Embarq should help you.
Apr 29, 2009 | Dell Microsoft Windows XP Home Edition
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Mar 14, 2009 | Apple AirPort Extreme Base Station
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Wireless connection
that unit has a driver problem, for the usb or ethernet, you might be able to re-install the specific drivers on their web site, and retry it there, unless the wireless in pci based and the you have a driver problem there, if you can use the ethernet connection then it's usb or pcmci, try that, if that doesn't work you need a tech to look at it.
hope this helps you out, let me know
Jun 15, 2008 | Acer TravelMate 2300 Notebook
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
