Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Mtd 46 cut can not level the deck, tire pressure (ok)the adjustment bolt on the left side of deck is no help.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
My riding lawnmower not cutting even, craftsman 46"
first check that the blade or mandrel is not bent or damaged --and check the air pressure in tires on right side --lower deck towards ground on a level surface until left makes contact now adjust the level arms they are on either side of cutter till right side is level with left on some of the older decks can adjust the front deck wheels also
Aug 25, 2016 | Craftsman Garden
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
My Craftsman riding mower doesnt cut EVENLY. How dow I adjust the deck components to get a flush cut?
You might start with making sure the tires are the same height as the one across from it. For years now the tires on the mowers seem to be nothing but a tube sock dipped in rubber, they all leak to some point.On my MTD I have a short 2 x 4 block of wood I stand on edge and push it up to the rear axle where it bolts to the body and air it up till it just slides under , then do the other side, need to match or one side of the deck is lower.On the front I had cut the length of that 2 x 4 block to the right height on end. On low pressure tires using a air gauge is not the same,wrapping a tape measure around them till the match is the rule but a pain. There is a way under the tractor to level the deck but this part needs to be right first because they go down from week to week. I also put a Dixie cub of antifreeze in each tire and as long as you use the mower regular it helps a bunch. After doing this matching tires part and it still need adjustment come back with Model number and I would be glad to continue helping you.
Mar 25, 2016 | Craftsman Garden
How to level the cut hight of a L130 Jphn Deere Lawn mower
Inflate all tires to the proper air pressure using a high quality gauge such as a digital, not the $3.00 ones but a good quality from say Napa. Make sure the tires are within the same wear of tread and inflated to + - 1/2 PSI of the proper pressure. Find a nice clean and flat surface to park and using a "Tee" square check the left and right rear "corners" of the deck. If you do not own a "Tee" square I've used large wood wedges that taper from 0" to 3" (such as a wedge made from a 2X4), slide the wedge until the tapered part just touches the rear corners of the deck and mark it with a pencil, do the same on the other side and then adjust the rear hangers until the deck is level within 1/8" or less side to side. Then adjust the front hanger to set the front of the deck 1/8" lower than the rear and you are there. From then on simply keep the tires inflated using the example above and your deck should go right back to level again.
If the out of level cut still persists check to ensure the blade tips are even with each other, one blade higher than the other could be a bend blade or a distorted deck and possibly a bad spindle bearing.
Aug 02, 2014 | John Deere Garden
Proper deck adjustment John Deere L111
FIRST, ensure the tires have the proper pressure within 1 psi.
The deck should be level side to side, measure from the driveway to the bottom lip of the deck with the height selector lever set so the anti gouge wheels suspended in the air. The side to side tolerance is about 1/8" max. Next measure the bottom lip in front and back (center), the front should be 1/8" lower than the rear.
Adjustments are made using the hanger bracket nuts, turn it left and the hanger lowers, turn it right and it raises. Most decks stay adjusted well, it's the tires and loss of pressure that causes poor cutting or wedge shaped rows. Check the air pressure before every cutting, if it's problematic take the tractor (or tires) and have tubes installed with self sealing compound inside such as tire slime.
Mar 11, 2014 | Garden
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD 603 cutter not level. Cuts low on RH and high on LH. Is there an adjustment to make.
First make sure that your tires are all aired up the same and then park it on level concrete. Drop the deck down on 4 short pieces of 2 x 4 set on edge. Then find your 4 deck hanger rods and adjust them individually until each corner of the deck just starts to come off the 4 2 x 4's. At this point your deck should be level. hope this helps you...
Sep 17, 2009 | Mtd Garden
42" deck not cutting level
I had a similar problem, and the problem was fixed by airing up one of my front tires. This may not be all of the problem, but you should eliminate this before you go adjusting.......
Just a thought, --W/D--
Aug 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Can't level deck.
try checking the blade spindle to see if there is any play (up,down,left,right) hope this helps
Jul 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
135 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
