Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on then click right off. You can hear what sounds like water running inside the box.
  • Mesman Mar 27, 2008
    Where can you find the parts. A local maytag dealer advised me that no parts are available and the skybox is no longer made. Do you know where the parts can be purchased?
  • 4,889 Answers
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Posted on Mar 26, 2008
  • eagle338
    eagle338 Mar 28, 2008
    I just saw this post on another site regarding the same problem.. Read this and decide what you want to do.. Just Thought before you invest any further on this you ma want to read this..
    My skybox quit cooling also, what happened
    to mine is the compressor would not start, I unplugged it, plugged it
    back in, it hummed for a second and tripped a reset, it would just keep
    doing it .I called an appliance tech, which by the way I am on a first
    name basis with on this skybox. He didn't even have to take his coat
    off or open his toolbox to tell me the compressor is shot and it is a
    sealed non-servicable part, and even if it could be fixed it would be
    at a cost more than I paid for the skybox. I called Maytag (Whirlpool)
    hoping they have a guilty conscience over these skyboxes and would
    extend the warranty to no avail. The customer service rep informed me
    that the compressors on these are made by Haier (the cheap Chinese
    refrigerator people) and it was designed as a throwaway unit. So after
    more than $700 invested in this thing over the last 2 years I cut my
    losses, shot it a few times with a 12 gauge and threw it away. Oh by
    the way the tecnician then gave me a bill for a $72,95 service call.
SOURCE:
Maytag Skybox has stopped cooling
the whirlpool part is the oem part and is the best part for your repair it should replace wire for wire and require very little instruction. the 3-n-1 will cause premature failure of the compressor and is not recommended. As far as I know there really isnt a service manual available for the skybox. It was a very limited production product that didnt stay available for very long. thnaks Peyton
Mar 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox not cooling
sounds like compressor relay --- if the fan and compressor come on and then shut off after about 5-10 seconds -- its the relay --- sometimes you have to also replace the transformer and capacitor on the opposite side of the unit --- all items are accesible from the back of the unit
Jan 23, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
good to hear another skybox lives...thanks for the kind words. alex
Dec 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
Go to www.apdepot.com and enter your model number under Brand :Maytag you will see a parts breakdown and you can buy it online
Oct 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox MBV1976AAB Compressor Start Relay
Hi, Relay switches can be found easily on amazon, take a look here: Check out TRENDnet latest products. Wish you best of luck.
John
Nov 15, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox not cooling
i just had the same problem.i emailed maytag and will let you know what they reply.keep in touch if you find the fix.
Sep 11, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
324 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Bailey's...
Bailey's...
Steve Allison
Steve Allison
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
