Question about Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer
Where is the idle adjustment screw on the stihl model 170 saw?
The owners manual says the adjustment screw is thru a hole on the side of the handle. But the hole in the handle doesn't line up with hole in the saw. I took off the handle and found out the adjustment screw is not where the manual says it is. Where is it? please help.
  • dontbother10
    dontbother10 May 11, 2010
    I tend to over simplify things. Why not ask the folk that make your saw? Stihl Contact Ushttp://www.stihlusa.com/contact.php
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
How? do i adjust the idling on my chainsaw
Generally you will find 3 small holes or slots on the pull cord side of the saw you will need a small enough slot screwdriver to fit through the holes. Depending on the age of the saw there will be a low speed adjusting screw a high speed adjusting screw and the idle set screw to establish which is the idle set screw remove the air filter cover from the top of the saw then the air filter you should be able to see the carburetor at this point, the screws should be on the left from the rear or handle end of the saw. The screw you are looking for should have a small spring on it and it should pass through an aluminum post and come against a metal lever of sorts on the top of the carb. When the screw is turned to the right the saw RPM should increase to the left should lower the RPM. When the RPM is lowered and the saw wants to stall the low speed screw will need to be adjusted. the low speed screw should have a blue plastic rotation stop on it and you may have to remove it to adjust the low speed adequately.
There is a new fuel made for 2 cycle engines that has a 50 to 1 rating and it cleans the carb and the internal saw parts. It's biodegradable and does not go stale in the saw. It's an amazing product. you should be able to get it at a chain saw dealer.Expensive but worth every penny. It comes in one ltr. or 1 gal. containers. Tune up in a can so to speak.
Hope this helps
BR
Jul 19, 2014 | Poulan Garden
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
Need owner or service or both manuals for Homelite model #UT10516
Robert:
As far as the manuals... you might be able to download them at http://www.homelite.com. (you can click on the link) under customer service, you'll find "owner's manuals). To adjust the fuel/air mixture, start the saw and turn the adjustment screws in or out a little at a time until you get the saw running properly. There is no "set" adjustment... as the saw motor ages, those settings will change. If you make adjustments to the fuel/air screws and the saw stops running and starting, turn the adjustment screws all the way in (clockwise) GENTLY... If you force those screws you will damage the needle valve seats! Turn both screws out one and a quarter turns out, and the saw will start. continue adjusting until the saw runs properly. Have patience... it may take a while to get the saw running to your satisfaction.
Jan 18, 2013 | Homelite Garden
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
How do I assemble the bar and chain on my 1.5hp chain saw MS1415?
Start by removing the bar nut/nuts, and remove the side cover, if the chainbrake is in the cover make sure this is off by pulling the hand guard fully back to the top handle, before removing the side cover, wind the chain adjuster screw fulley in toward the rear of the saw ( it may be in the crankcse, or in the side cover ) now assemble the guide bar onto the bar bolt/bolts, loop the cutter chain over the sprocket,and into around the tip of the guide bar, and into the bar rails, make sure the sharp end of the cutters on the top of the guide bar are facing away from the saw ( the chain rotates clockwise as you look at it ) now align the adjuster hole in the bar with the adjuster pawl on the machine, now re fit the side cover, if the adjuster pawl is in the cover make sure this lines up with the adjuster hole in the bar, assemble the bar nut/nuts finger tight, adjust the chain so as it touches all the way around the guide bar ( not sagging on the bottom of the bar ) with a gloved hand pull the chain around the bar to make sure it is free and sitting in the sprocket correctly, re adjust the chain if required, now lift the nose of the bar and fully tighten the bar nut/nuts
Feb 10, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
Trying to put chain and saw together
If the saw has a chainbrake make sure it is de activated by pulling the hand guard fully to the top handle, you should hear an audible clip when it locks, remove the the bar nut/nuts and remove the side cover, if the chain adjuster is in the cover screw it right back, if the adjuster is in the crankcase screw it right back, place the guide bar onto the bar bolts, loop the chain over the sprocket and lay it around the guide bar with the cutters on the top of the bar facing away from the saw, if the adjuster pawl is in the crankcase locate it into the adjuster hole in the guide bar, now re fit the side cover, if the adjuster pawl is in the cover make sure it locates into the adjuster hole in the guide bar, re fit the bar nut/nuts finger tight, screw the adjuster up until the chain sits snuggley around the whole guide bar, pull the chain around the bar manually with a gloved hand, this will make sure it turns freely and is correctly located in the sprocket, hold the end of the guide bar up and tighten the nut/nuts
Jan 23, 2011 | McCulloch Garden
How do i replace my chain on my Partner brake assisted chain saw ?
Make sure the brake is de activated by pulling the hand guard fully back to the top handle, you shpuld hear an audible click when it locks, remove the nuts and side cover, the chain adjuster will either be in the crankcase or the side cover, screw the adjuster right back, remove the old chain, now loop the new chain over the sprocket and lay it into the guide bar with the cutters on the top of the bar facing away from the saw, re fit the side cover making sure the adjuster pawl locates into the adjuster hole in the bar, re fit the bar nuts finger tight, screw the adjuster up so as the chain sits snuggley all around the guide bar, pull the chain around manually with a gloved hand, this will make sure it is properly located in the sprocket and is free in the bar, lift the bar nose and fully tighten the bar nuts
Jan 23, 2011 | Garden
Hi I have a Husqvarna 350 chain saw that reaves way to fast almost to the point you think its going to blow up, thats when i chock it out to stop it. I have tried to make all the...
When you say you have made all the adjustments, are you referring to the idle speed screw adjustments? If so, have you turned down the High idle adjusting screw? Sometimes these get stripped, and it doesn't end up doing the job it should.
One other thought: If you don't have spring tension on the throttle trigger in the handle, the linkage may have popped off inside. This is kind of a pain in the *** to fix, because there is a spring mechanism inside the trigger handle, and the linkage is a strong bent metal bar that winds its way into the motor and fits into a hole in the throttle assembly, but is not well shown on the parts diagram for the saw from Husky. If this is the case, I can go through the process with you on a followup.
Aug 24, 2010 | Husqvarna 450 e-series 18" Chain Saw
My makita 2703 blade movement quirks
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_2703.pdf
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/2703.pdf
Here are two links for the parts manual and the owners manual. It is not uncommon for a tool to go slightly out of line with use due to vibration and and movement of the arbor. As for the tool not tilting, it just sounds like the worm screw and gear are off line. this is a pretty quick fix but it requires you to turn your saw upside down to access the set screws. I glanced at the diagram and it looks like the handle for the adjustment is held on by a set pin. you will also be able to access this from inside the cabinet.
Feb 24, 2010 | Makita 2703 10" Table Saw, Electric Brake
Problem aligning the adjustment block of chain tensioning screw
line up the adjustment block and put the screw into the hole. then carefully snug it down and put the cover back.
Sep 07, 2009 | Garden
Oregon Scientific Complete Carburetor for Stihl 4122 Brush Cutter and 4226HS Hedge Trimmer Logo
177 people viewed this question
Top Oregon Scientific Garden Experts
Dan Connors
Dan Connors
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
