Question about Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
Subwoofers don't work
I was listening to my stereo system on my way home from work and I smelt something burning. After a short distance the subs stoped working. When I opened my trunk the amps were on and not hot. The smell was comming from the two subwoffers. Now I removed the subwoffers the next day after trying them again with no such luck. The subs are on my kitchen table and there is no noticable damage to them. The smell I smelt when I was driving was comming from the magnet area inside the speaker. Now what do I do.
  • 94 Answers
That is 100% fried voice coils, please add more info, what type of subs your using, also the amps, gauge of the wire, also please add the specs for the amps such as max peak and rms, same with the subs and just the gauge of your power, ground and speaker wires you are using for the subs
Posted on Jun 07, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
The voice coils are probably fried. you may want to check your amps to see if they are putting out dc voltage. you may be abel to find a place that can fix the subs. otherwise you will need to replace them.
Posted on May 06, 2010
How do I hook up the sub woofer to my home stereo system
You don't say what make or type either of the appliances are, so I can only answer in general terms.
First look at the back of your stereo system and see if there is a dedicated subwoofer output. If there is you should be able to find the correct lead between the two units by looking at both the connections. If the subwoofer is a powered one. IE with a mains plug on it, you have to plug it into the mains before it will work at all. The connection points also then need to be hooked up to the amp. If it's not a powered subwoofer then your main left and right channels speaker wires need to be split into using the subwoofer terminals provided. Another set of terminals on the sub, then lead to the main speakers.
Lastly if it has a dedicated subwoofer output, then the amp might have a setting that turns this on or off. So you might need to switch it on.
Oct 19, 2016 | home Audio Players & Recorders
My subwoofer will not work with my receiver.
I had a similar problem where the subwoofer was working during calibration but not on TV viewing. Here is what I found:
  • That some listening/surround modes did not support the subwoofer.
  • Some receivers only support subwoofer with digital inputs.
  • Might also want to double check the speaker config and make sure it's has the subwoofer enabled.
  • I assume you're using the sub-pre-out to drive the powered subwoofer.
  • Have your tried a CD or FM radio station to see if you're getting the sub output from these sources?
Jan 08, 2015 | Yamaha RX-A840 AVENTAGE home theater...
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
I have a Box With 2 audiobahn 1200 Q 700 Watt Subwoofers and I hooked them up to my home stereo and noting at all comes out of them.... Is there any way i can fix them or get them fixed they are very...
Your home stereo is a 120V system, while your subs are designed for 12V use. Your home stereo doesn't have the amps to push your subs. They need alot of amps at 120V. Your best bet is to is an AC to DC converter, but to get one that is powerful enough to run your system would be more expensive than just buying a decent set of home subs. Also, your box design for home audio is different that car audio. Home enclosures usually use a bandpass box, while car enclosures rarely use this method.
May 04, 2011 | Car Audio & Video
I have a pioneer home theater HTZ585 DVD system. Since yesterday, i get 'SUB COM' message displayed (blinking) and nothing seems to work anymore. Any suggestions?
I can't find that message in the manual but I would guess it's trying to tell you something is wrong going out to the subwoofer. Trace the wiring. If you don't see anything wrong, disconnect the sub and see if the message disappears or changes.
Apr 30, 2011 | Pioneer 740 DV Home Theater System System
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
Jvc home stereo subwoofer
just chek the cables.. f it not work open the sub box , and check the sub speaker., , , , maybe the wire is burnd
Mar 01, 2008 | Audio Players & Recorders
Alpine mrp-m650 amp cutting out
Some AMPs have a thermal cutout, that switches the amp off if it gets too HOT.
But this sounds like your amp or sub is screwed, either there is to much resistance in your sub, eg: Burnt voice coil, carbon builds up on the coil stopping the sub from moving freely. Push on the cone of the sub & listen for a scrapeing sound.
or test this by continuity testing the sub terminals & pushing the cone if the BUZZER on the MultiMeter cuts in & out as you push & release then your sub is screwed. ( a certain amount of repeatative pushing it may free up the voice coil.)
or your Amp may have blown a internal fault that will have to be sent of for repair.
Or you have a incorrectly rated fuse for your system,
or the battery cant kope with the power surges???
THIS DOES NOT APPLY TO YOU AS YOU HAVE A POWER-CAP!!!
Dec 19, 2007 | Alpine MRP-M650 Car Audio Amplifier
Sony 12" Single-Voice-Coil 4-Ohm Subwoofer Logo
104 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
