Question about Kenmore Elite Oasis 27052 Top Load Washer
Function code F1?
THe machine is beeping, it's at the end of the cyle, but the function code 'F 1" is flashing.
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
I don't have a manual so trouble shooting is difficult. The problem is as the oven heats it periodically displays F-1 and beeps. I'm trying to use regular bake cyle. What does this mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 21, 2011 | Kitchen Ranges
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
Jan 11, 2011 | Ovens
Washer flashes f 1 and will not start
The range/stove fault code page....
My Range is flashing a "F" something.....what does this mean??
Some terms used on this page...ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction. Oven temperature sensor - What a common sensor or temp sensor looks like.
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic by Make and or problem...hope you find this helpful :-)
A tip for the famous F1 fault code entr_anm.gif The biggest Fault Codes list that I am aware of! What does an oven temp sensor look like?Some info and tips on oven temp sensors
Newer 4 digit fault codes - Maytag, JennAir, Magic Chef Newer Frigidaire fault codes new25.gif Some newer GE built in oven fault codes are here. Newest Hamilton built GE clock fault codes are here. I have some of my own hand written fault codes, here and some more here. The Maytag Gemini range fault codes are on this page. The Maytag Accellis range codes are on this page. traffic_record.php?lc=024041009290002517 A tip:The supplier recently reversed the display areas for the clocks. Therefore you may find an F1-E0 code or E0-F1 code depending on the model. They both mean the same thing, and depending on the model determines the code reference, and location of the F code. Different manufacturer of the clocks caused this.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error code and beeping on a ge doubleoven
Hello there:
Jan 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Why would my whirlpool cabrio washer flashes F1 and beeps
HI, this F-1 code represents a failed Machine/Motor control board.(primary control failure). Have this board replaced asap, if possible. replacing this failed board will fix this issue.
Aug 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore Elite Oasis 27052 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
