Question about GE Washing Machines
Washer fills with water, but then wont run
Washer fills with water, but the agatator wont move, or drain. makes low hum sound
  • Anonymous Mar 26, 2014
    i used a chisel, but they wouldnt move
  • 159 Answers
Check belt underneath has not broke or come off.
Posted on May 06, 2010
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Washing machine keeps filling and draining at the same time and wont fill enough to move on to the next cycle
The drain hose is too low and the water just runs right out...The highest point of the drain hose needs to be higher then the top of the washer before it goes back down into the drain. Also if the hose is sticking into water it can create a siphon which pulls the water out of the washer... make sure that you also have an air gap...
Heatman101
Mar 10, 2010 | Frigidaire FGX831C Top Load Stacked Washer...
Wont fill with water
Check the hose filters, open the valve with the hose disconnected to make sure you have good pressure. Your water control valve may be bad, but both sides don't usually go bad at once.
May 05, 2009 | Washing Machines
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
111 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
