Question about Electrolux ER6641T Compact Refrigerator
I have a model RM181HR 3 way 41 litre fridge.It has 75 watt 12/240 volt and 2.75 kpa propane gas.Refrigerant is 0.24kgs NH3 absorption.The fridge has been tried on all three systems.Heaters work as does the gas but it will not cool down.
2 Suggested Answers
SOURCE: Hi i have a 3
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
Posted on May 29, 2008
My fridge is a 3 way dometec caravan fridge for a 2016 challenger sport caravan, how do I put it on battery whilst towing
Speaking from over 15 years of RV experience (including 7 years of professionally delivering them from factories), truthfully, you should avoid the 12 volt function on an RV absorption type fridge. The dirty little secret RV dealers never tell you is the 12 volt function on a 3 way fridge, is not a useful option and more of sales feature. They draw a LOT of power so if you forget to switch to propane or shore power when arriving at the campsite, you will kill the house battery in no time. If you are stopped for any length of time and still hooked to the tow vehicle, you may also kill your tow vehicle battery too. And if your tow vehicle 12 volt power supply wire is not functioning properly, you will kill the house battery, while travelling. A much better solution is to pre-cool the fridge at home before departing, by connecting to the house power overnight. Put some freezer packs in the freezer compartment and they will keep the fridge cold. I know this does not answer your question, but trust me, this is the best route. Happy RVing!
Jun 22, 2016 | RVs
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
I have a Dometic RM3801 rv fridge that was working fine on 120v and then stopped cooling. All the lights come on but the compressor won't run. It is level and the cooling fins are clean. I checked power at...
your refrigerator is an ammonia absorption system it does not have a compressor only a series of closed pipes and small tanks located behind the styrofoam box so; to operate yout refrigerator you need: a propane flame or, a 12 volt heating coil or an AC transformer to heat the system depending on if you have a 1,2,or, 3 way system.
also; these refrigerators will only work if you are on level ground
so check your fuses, transformer and, or, your gas thermocouple:
the thermocouple is a rod that sits in the burner flame to control the gas valve if you see some yellow dust around the back of the refrigerator you have a leak of the sealed system don't buy a new refrigerator just replace the system and, be sure that you remove the twisted metal riser in the top of the refrigerator vent pipe to use in your new system or, nothing will work the ammonia absorption sealed systems can be bought on ebay etc.
Sep 25, 2013 | Refrigerators
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
Wattage use
Your calculations is correct - 220 X 0.7 = 154 watts.
If your fridge only runs on 220 volts then you need solar panels that charge 12 volt lead acid batteries and then use a inverter to convert 12 volts DC to 220 volts AC.
Jan 13, 2012 | Kelvinator Refrigerators
Need location for 2003 Pontiac Montana AC low pressure switch
Hello, this vehicle doesnt use a cycling switch. it uses a pressure sensor. this compressor runs all the time. there is a expansion valve that controls the amount of freon entering the evap core. here is how the compressor uses a pressure senor
The A/C refrigerant pressure sensor is a 3-wire piezoelectric pressure transducer. A 5-volt reference, low reference, and signal circuits enable the sensor to operate. The A/C pressure signal can be between 0-5 volts. . When the A/C refrigerant pressure is low, the signal value is near 0 volts. When the A/C refrigerant pressure is high, the signal value is near 5 volts.
The A/C refrigerant pressure sensor protects the A/C system from operating when an excessively high or low pressure condition exists. The PCM disables the compressor clutch under the following conditions:
• A/C pressure is more than 2979 kPa (432 psi). The clutch will be enabled after the pressure decreases to less than 1620 kPa (235 psi).
• A/C pressure is less than 179 kPa (26 psi). The clutch will be enabled after the pressure increases to more than 207 kPa (30 psi).
Jun 08, 2011 | 2003 Pontiac Montana
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
Does my old propane fridge have a element ?
Propane refrigerators have a gas burner to create the heat for refrigerant circulation. Some propane refrigerators that were used mostly in RV's also had an electric heat element that ran off a power cord or 12 volt battery.
To determine this look at the back of the refrigerator, you will see a gas line that ends in a burner on the lower left side (looking from the back). Just above that about 4 inches will be wires coming out of the box if an electric heat element is used.
Apr 18, 2010 | Dometic NDR 1062 Refrigerator
My dometic rm 2612 stops working at least once a day the check light goes on.
Your 'frige has either; a 12 volt power supply or, a gas flame to circulate the refrigerant gas to cause absorption refrigeration to work; check or, replace your power supply as it 1. holds open the gas valve relay, 2. heats the gas with a heating element.
Mar 30, 2010 | Dometic RM2620 Refrigerator
Thetford fridge type C11[fitted to caravan]model N80 PL R
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
Jan 04, 2009 | Thetford Porta Potti
Electrolux ER6641T Compact Refrigerator Logo
43 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
