Smeg washer/dryer not filling
I've got a Smeg Allegra front-loading washer/dryer. the washing cycle is going around, but machine won't fill with water, so nothing is happening (this just happened, so nothing else has changed, water is on etc)
  • 52 Answers
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Posted on Mar 26, 2008
WHAT DOES "E5" error code means? I've got a KELVINATOR KTD600MD T/DRYER
water not been filled quick enough have you made sure the water is turn on fully and check the filter they get clogged up
Sep 12, 2013 | Smeg WDI12 Front Load Washer / Dryer
Error code
The E10 error code indicates the control does not see a proper fill. Here are a few things you can easily check. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
Apr 22, 2012 | Smeg WDI12 Front Load Washer / Dryer
Smeg washing machine stuck on pause
If the machine won't start then it will most likely be the door latch that is at fault.
Mar 12, 2012 | Smeg WDI12 Front Load Washer / Dryer
I would like to know how many gallons of water this machine uses per washload. Maytag Epic Front load Washing Machine Model # MFW9800TQO
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
Mar 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
