Question about RTO Cal Torpedo Pump 7500 Gph
I have a water fall that is 5ft. hi and 25 to 30 ft. long what size will the pump have to be to cover it with water.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
2005 chevy silverado water pump bolt torque specs
What size engine ? This vehicle could have six different engines .
Water Pump Replacement (4.8L, 5.3L, and 6.0L)
Install the water pump bolts.
Tighten
  1. Tighten the bolts a first pass to 15 N?·m (11 lb ft).
  2. Tighten the bolts a final pass to 30 N?·m (22 lb ft).
Water Pump Replacement (4.3L)
Tighten
Tighten the bolts to 45 N?·m (33 lb ft).
Jun 24, 2016 | Cars & Trucks
Its not cooling
Hi David:
REMOVAL & INSTALLATION (see Figures 1 and 2)
Drain the cooling system.
CAUTION: When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
Fig. 1: Water pump assembly-Z24i and KA24E engines
Fig. 2: View of the water pump assembly-VG30E engine
Remove all drive belts.
Unfasten the fan shroud securing bolts and remove the fan shroud assembly.
Unfasten the water pump retaining bolts (note the different size bolts on the VG30i and VG30E engines), then remove the water pump and fan assembly, using care not to damage the radiator with the fan.
If the fan is equipped with a fluid coupling, do not tip the fan/pump assembly on its side, as the fluid will run out.
To install:
Remove all traces of gasket and/or sealant from the pump-to-cover mounting surfaces. Install the water pump and tighten the M6-size mounting bolts to 3-7 ft. lbs. (4-10 Nm). Tighten the M8-size bolts to 7-12 ft. lbs. (10-16 Nm) on Z24i engines, or 12-15 ft. lbs. (16-21 Nm) on KA24E, VG30i and VG30E engines. Always use a new gasket between the pump body and its mounting.
The KA24E engine uses a liquid gasket. Carefully scrape any old gasket material from the mounting surfaces, then apply a 0.079-0.118 in. (2-3mm) continuous bead of liquid gasket around the entire mounting surface.
Install the fan shroud assembly.
Install the drive belt and adjust the tension.
Refill and bleed the cooling system
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 14, 2011 | 1991 Nissan Pickup
What is 5 ft 6 ins in metric
Since you have your calculator, I'll just help you with the conversion.
1 foot = 12 inches
1 meter = 39.37007 inches
5 ft *12 inches + 6 inches = 5ft 6 in --- ans1
ans1 / 39.37007 inches = ans2
ans2 will be your final answer.
Hope this helps.
May 30, 2011 | Office Equipment & Supplies
Need R&R information to replace for waterpump Geo Storm 1993 4 cyl
Hi!!
Here is the Info you requested:
WATER PUMP REMOVAL & INSTALLATION
Except Twincam Engines See Figures 1 and 2
  • Disconnect the negative battery cable and drain the cooling system.
  • Loosen the power steering pump adjustment bolts and remove the drive belt.
  • Remove the timing belt; refer to the procedure later in this section.
  • Remove the tension pulley and spring.
  • Remove the water pump mounting bolts, water pump and gasket. Clean the mounting surfaces of all remaining gasket material.
  • To install, reverse the removal procedures. Tighten the water pump bolts to 17 ft. lbs. (23 Nm) and the tension pulley to 30 ft. lbs. (40 Nm).
  • Connect the negative battery cable and fill the cooling system, then start the engine and check for leaks.
Twincam Engines See Figure 3
1.6L DOHC ENGINE
  • Support the engine using a suitable floor jack and remove the right front engine mount.
  • Remove the engine mount bridge and the upper timing belt cover.
  • Remove the power steering belt and the lower timing belt cover.
  • Loosen the timing belt tension pulley and remove the timing belt.
  • Remove the power steering pump and bracket.
  • Remove the water pump attaching bolts, then the water pump from the vehicle. Thoroughly clean all remaining gasket material from the mating surfaces.
  • Reverse procedure to install and tighten the water pump bolts to 17 ft. lbs. (24 Nm). Connect the negative battery cable and refill the cooling system. Start the engine and check for leaks.
1.8L ENGINE
  • Disconnect the negative battery cable and drain the engine cooling system.
  • Remove the timing belt covers; refer to the procedure later in this section. Loosen the timing belt tensioner pulley bolt, then remove the belt from the water pump pulley.
  • Remove the 2 bolts from the power steering pump bracket, then position the pump aside with the lines still attached. Be careful not to kink or damage the steering fluid lines.
  • Remove the water pump mounting bolts, then remove the pump from the engine. Thoroughly clean the gasket mating surfaces of all remaining gasket material.
To install:
  • Install the water pump using a new gasket, then tighten the retaining bolts to 18 ft. lbs. (24 Nm).
  • Position the power steering pump assembly, then install the retaining bolts and tighten to 25 ft. lbs. (34 Nm).
  • Install the timing belt to the pump pulley, then tighten the tensioner pulley bolt to 30 ft. lbs. (40 Nm).
  • Install the timing belt covers.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 11, 2011 | Geo Storm Cars & Trucks
How do you replace water pump?
Assuming this is a 460 Ford Big Block:
REMOVAL
-Drain cooling system.
-Remove drive belts.
-Remove bolts attaching fan shroud to radiator.
-Remove fan blade from fan clutch and remove fan shroud.
-Remove fan clutch and water pump pulley from water pump.
-Remove four bolts and one nut attaching A/C compressor mounting bracket to cylinder head and water pump. Do not remove A/C compressor or power steering pump from A/C compressor mounting bracket.
-Pull A/C compressor mounting bracket forward to remove from stud on water pump.
-Remove bolt attaching generator adjusting arm to water pump. Remove four bolts attaching generator mounting bracket to cylinder head, cylinder block and water pump.
-Remove remaining water pump attaching bolts and remove water pump from engine front cover.
-Remove water pump cover from water pump. Discard water pump housing gasket and water pump cover gasket.
INSTALLATION
-Remove any gasket material from water pump cylinder front cover and separator plate mating surfaces.
-Position new water pump housing gasket and water pump cover gasket coated on both sides with Perfect Seal Sealing Compound B5A-19554-A or equivalent water-resistant sealer meeting Ford specification ESE-M4G115-A.
-Position water pump and water pump cover onto engine front cover. Install bolts and tighten to16-24 Nm (12-18 ft. lbs.).
-Install generator mounting bracket to cylinder head, cylinder block and water pump with four attaching bolts. Install generator adjusting arm to water pump with one attaching bolt. Tighten 7/16-inch bolts to 54-71 Nm (40-53 ft. lbs.) and 3/8-inch bolts to 41-54 Nm (30-40 ft. lbs.).
-Position A/C compressor mounting bracket over water pump stud and secure to cylinder head with four bolts tightened to 54-71 Nm (40-53 ft. lbs.) and secure nut to water pump to 41-54 Nm (30-40 ft. lbs.).
-Install water pump pulley and fan clutch to water pump hub with four bolts. Install fan blade to fan clutch with four bolts. Tighten water pump pulley, fan clutch hub bolts, and fan-to-fan clutch hub bolts to 16-24 Nm (12-18 ft. lbs.). Install fan shroud.
-Install drive belts.
-Fill and bleed the cooling system.
-Start the engine and check for leaks
Jan 10, 2011 | 1997 Ford F350 Crew Cab
Drain header is approx 6 ft. high-Will the washer pump push water
Hi there.I would try a load with it at that hieght,fill the machine to its highest water level,if the machine has still got water left in it afterwards then there might be a problem.Let me explain something..Washing machines these days have weak pumps designed with a low velocity,not very powerful.they designed to pump only to a 4 or 5ft head pressure wich is just above the water level height in the machine.most pumps are electric but earlier machines had belt driven pumps running straight from the powerful wash motor.nothing could slow them down.Actually your machine might have the pump directly attached to the motor so your is probably running of the main wash motor..I think you will be fine but try what i said anyway in the beginning.hope this help ya!
Jun 03, 2010 | Kenmore 24032\24036 Top Load Washer
How to change a water pump on a 1995 ford windstar
Fig. 1: Front cover and water pump bolt size and location-3.0L engine
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Loosen the four water pump pulley retaining bolts while the accessory drive belts are still tight.
  4. Rotate the automatic tensioner down and to the left.
  5. Remove the accessory drive belt.
  6. Remove the two nuts and bolt retaining the drive belt automatic tensioner to the engine, then remove the tensioner.
  7. Disconnect and remove the lower radiator and heater hose from the water pump.
  8. Remove the eleven water pump-to-engine retaining bolts, then lift the water pump and pulley up and out of the vehicle.
  9. Remove the water pump pulley retaining bolts, then remove the pulley from the water pump.
To install:
Be careful not to gouge the aluminum surfaces when scraping the old gasket material from the mating surfaces of the water pump and front cover.
  1. Clean the gasket surfaces on the water pump and front cover. Lightly oil all bolt and stud threads except those requiring special sealant.
  2. Position a new water pump housing gasket on the water pump sealing surface using gasket sealant to hold the gasket in place.
  3. With the water pump pulley and retaining bolts loosely installed on the water pump, align the water pump-to-engine front cover, then install the retaining bolts.
  4. Tighten the bolts to the following specifications:
    1. Bolt numbers 1-10: 15-22 ft. lbs. (20-30 Nm).
    2. Bolt numbers 11-15: 71-106 inch lbs (8-12 Nm).
  5. Hand-tighten the water pump pulley retaining bolts.
  6. Install the automatic belt tensioner assembly. Tighten the two retaining nuts and bolt to 35 ft. lbs. (47 Nm).
  7. Install the alternator and power steering belts. Final tighten the water pump pulley retaining bolts to 15-22 ft. lbs. (22-30 Nm).
  8. Position the hose clamps between the alignment marks on both ends of the hose, then slide the hose on the connection. Tighten the hose clamps to 20-30 inch lbs. (2.2-3.4 Nm).
  9. Fill and bleed the cooling system.
  10. Connect the negative battery cable.
  11. Start the engine and check for leaks.
Hope this help; good luck and remember rated this post.
May 15, 2010 | 1995 Ford Windstar
Water pump
You should not have to do all that. Let me know if you dont get diagral(sometimes happens)
  1. Drain the cooling system.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. 0900c1528018cf80.jpgFig. 1: Water pump assembly-Z24i and KA24E engines 0900c1528018cf81.jpgFig. 2: View of the water pump assembly-VG30E engine
  1. Remove all drive belts.
  2. Unfasten the fan shroud securing bolts and remove the fan shroud assembly.
  3. Unfasten the water pump retaining bolts (note the different size bolts on the VG30i and VG30E engines), then remove the water pump and fan assembly, using care not to damage the radiator with the fan.
To install:
  1. Remove all traces of gasket and/or sealant from the pump-to-cover mounting surfaces. Install the water pump and tighten the M6-size mounting bolts to 3-7 ft. lbs. (4-10 Nm). Tighten the M8-size bolts to 7-12 ft. lbs. (10-16 Nm) on Z24i engines, or 12-15 ft. lbs. (16-21 Nm) on KA24E, VG30i and VG30E engines. Always use a new gasket between the pump body and its mounting.
  1. Install the fan shroud assembly.
  2. Install the drive belt and adjust the tension.
  3. Refill and bleed the cooling system (refer to ), then start the engine and check for coolant leaks.
Feel free to reply with any questions or comments
Nov 14, 2008 | 1993 Nissan Pathfinder
2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Sep 08, 2008 | 2005 Hyundai Tucson
RTO Cal Torpedo Pump 7500 Gph Logo
53 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
