Question about Magellan Maestro 4040 GPS Receiver
Won't turn on.
Brand new. Used 5 times. Even when plugged into lighter, unit will not turn on.
    President:
  • 1,111 Answers
If you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
Posted on May 10, 2010
    President:
  • 1,851 Answers
I own a Magellan myself and I have found this same situation. I had let the fuse come loose in the unit.
Try this -
Try something else in the lighter.
2- if the lighter is good - try this
3- the Magellan uses a mini USB plug - - using a mini USB plug - plug the unit into your pc and run the software that came with the unit. Try using a wall plug to charge the battery. If your unit is only used 5 times you may be able to return it. I had this same problem and used a MINI- USB cell phone plug for the WALL unit - 110 electrical and it worked to charge my unit. So best of luck. The problem seems to just be a dead battery that requires an overnight charge from the wall plug for it or a cell phone charger substitute
won't turn on. - f5305dd.gif.
Posted on May 06, 2010
  • 43 Answers
This is a known issue with thid unit. I would contact Magellan about a replacement if you have had it less than a year.
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
My nes wont even turn on, used to work just perfect
Have you checked your power adaptor if it has become faulty. some time the plug end maybe faulty or the unit. leave it on for an hourand feel if the unit is worm some times this indecate if it is working and it may be a cable issue. New Adaptors are found at http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/nintendo-nes-power-adaptor-brand-new.html
www.gameoz.com.au
Mar 11, 2010 | Nintendo NES Console
Garmin 1390T Won't turn on - Unless Plugged in car lighter
theb battery is faulty or has not received a proer charge time to allow it to run. If after charging for a longer time 5-6hrs it still plays up return it for a replacement or warranty repair
Jul 19, 2009 | Garmin nuvi 200W GPS Receiver
Brand new Magellan Maestro 4000 does not turn on or indicate powe
I had the same problem and I solved it by cutting a few strands of speaker wire and twisting them together and inserting them into the center of the generic car gharger end which plugs into the Maestro 4000, It seems that the 4000 has a very small center conducter on the GPS itself and by adding a few strands of speaker wire about 1/2" long into the plug before pluging it into the 4000 it allows it to makes contact with the small power inlet conductor which is smaller than most generic cigarette lighter 5vdc power cords. I did this to mine and it powered up right away. The other solution is to buy the actual car power cord from Magellan which has the proper size connecton and makes proper connection all the time.
Dec 24, 2008 | Magellan Maestro 4000 Handheld GPS...
Auto shut down screen does appear when ignition is turned off
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Nov 28, 2008 | Garmin Nuvi 660 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
402 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
