Question about Canon PIXMA® MP530 All-In-One Printer
Alarm button on printer and a error code of 5110
  • 4,041 Answers
Hi there
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on May 06, 2010
  • 52 Answers
SOURCE: Canon pro9000 Carriage lift mechanism error [5110]
hi i am a certified Canon repair tech for this printer. this machine has a service bulliten for this problem and i have preformed the repair of this problem. the carridge lift cams are rotating faster then they should due to the wrong grease being applied to the part at the factory. this will require a Canon service center to repair because they is a special grease that needs to be used to slow down the cams. the best way is to contact Canon at 1-800-OK-CANON to locate a service center near you and they will repair the machine under the warrenty. hope this helps.
Posted on Jan 05, 2008
hashchathy
  • 246 Answers
SOURCE: error code 5110..please help in my printer Mp600
try to reinstall the printer dirvers
Posted on Feb 13, 2009
halbrook
  • 560 Answers
SOURCE: Message on printer screen is simply Error Code 5110
I found this on another site. It is for error code 5100 but since nobody seems to find the exact answer for 5110, maybe you should give it a try. If this helps, email a "thank you note" to the person who wrote this, his email address is at the end of this message.
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100. Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Wayne Lischynski - Ebytes Computers
wayne@ebytesonline.com
Posted on Apr 29, 2009
cene765
  • 787 Answers
SOURCE: error code 5110 on canon mp830 copy and alarm
5110 is Carriage lift mechanism error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Posted on Nov 17, 2009
  • 123 Answers
SOURCE: Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Posted on Jul 21, 2010
094-402 error code resolution?
web search dell laser printer error codes
Sep 15, 2015 | Dell 5110cn Color Laser Printer 5110 Cn
What is the Canon MX850 Error Code 5110?
The paper goes in from the front, under the 'paper output' tray.
Feb 14, 2015 | Canon PIXMA Office Equipment & Supplies
Error code 5110
5110 Carriage lift mechanism error
Feb 02, 2014 | Canon Pixma iP6600D InkJet Photo Printer
I continue to get a (check printer error 5110) alert. I have turned off he printer and then back on but a yellow alarm light keeps coming on can you please help me get rid of this error! karen...
Error 5110 means Carriage lift mechanism error. This is a Canon-specific error code for its printers. Aside from this error, usually there's a sequence of alternate blinking in orange and green of the LED light(alternating cycle of green and orange lights x 11)
Its one of the Service Call Errors which means a part of the printer is missing or broken, and needs to replaced or repaired by a Canon Authorized technician.
Solution (Replacement of listed parts, which are likely to be faulty):
- PR lift shaft
- Sheet feed unit
- Logic board
- Carriage lift sensor unit
Disclaimer:Things you can do if you know how to work with printers(Advanced), if this printer is under warranty and/or this will be the first time that you're gonna work/ troubleshoot this printer and/or you definitely have a hard time understanding these terms I've mentioned better call an Authorized Canon printer technician
  • If you know a lot about printers you can take the printer apart and see whether you can cycle/roll the wheels at the purge unit and the greater wheel which lifts the carriage unit freely. These wheels are behind the main board at the right side, so you have to dismount all the cables and the main board with its cage at the bottom screws.
Hope this info helps!
Jan 25, 2011 | Canon PIXMA MX310 All-In-One Printer
What is error code 5110 mean?
According to the manual, error 5110 means "Carriage lift mechanism error".
It's usually related to cartridges, particularly if they not inserted correctly, but can also be caused by other mechanical failures.
Apr 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5110 canon MP830 all in one printer at first i had an error code 6A00 after cleaning the printer head and rdestarting my printer I then received an error code of 5110 my email is thank you
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Dec 30, 2009 | Canon Office Equipment & Supplies
Error code 5110 on canon mp830 copy and alarm flashing
Nov 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA® MP530 All-In-One Printer Logo
212 people viewed this question
old marine
old marine
