Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
How to set up wpa2 encryption on netopia 3347wg
I need step by step directions and default ip address. was given this router with no manual so have no basic info on this unit and no experience with this. is there a good website with instructions?
thanks
bigdawg
5 Suggested Answers
  • 37 Answers
SOURCE: My website on my network open the netopia router page
You need to somehow setup the internal DNS to route all requests for the specific domain name, to your internal website.
Or, setup the netopia to allow loopback connections.
If you have a 2003 Server OS, chances are that the server is handling DNS requests, at least internally.
This tutorial has a good example of how to create domains internally:
http://www.simongibson.com/intranet/dns2003/
Just a couple of tidbits when using this approach:
You will essentially be controlling the DNS for the domain internally anyways. Meaning, any subdomains, mail exchangers etc., for the domain will have to be configured as well.
Good Luck.
Posted on Mar 10, 2009
spincycleus
  • 62 Answers
SOURCE: could you walk me thru
in the ATT region, they use PPPoE (in general, even if you have sticky static IPs)
plug in the router, turn it on, open Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
click on configure, then click on quickstart
type in your username (the emaill address from ATT like lc61544@att.net) and your password for your email address
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, you can open IE or firefox, whatever
and see if you're online (you should be)
spin
Posted on May 01, 2009
  • 192 Answers
SOURCE: Cannot get to router configuration screen
If you are using Internet Explorer, you must prepend http:// to the IP address to go there.
1) type http://192.168.1.254 into the browser window and you should go right there.
2) assuming that you are using the default configuration of the router, this should do the trick. Otherwise, you may have to manually place the laptop on the same network as the router.
Try #1 first, and see if that doesn't give you access.
I hope this helps.
Posted on Aug 18, 2009
Testimonial: "Thanks for the help!"
  • 11800 Answers
SOURCE: was given an older netopia 3347-02-1006L "type
Reset it again as explained here
http://www.netopia.com/support/hardware/technotes/CQG_102.html
If necessary do it using the serial connection.
If it behaves the same then the router firmware has been corrupted and the only way to save this router is to reload the firmware by using the serial connector - a special bootloader will have to be used. You must request for it specifically from them. Use this form to get registered
http://www.netopia.com/support/hardware/firmware/updates.html?3347-02-1006dl
and then request it.
Posted on Aug 10, 2011
Wpa code for ps3
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Apr 13, 2012 | Netopia Computers & Internet
Change Router Settings - IP Address not working
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 25, 2012 | Linksys Computers & Internet
Where is my wep key on my netopiaW router
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Feb 27, 2012 | Netopia Cayman 3347W-Ent Wireless Router
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
I want to set up password on my router
Step 1 Open a web browser and type the IP address of the DIR series router into the address bar (default is http://192.168.0.1). Press Enter
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click on OK.
Step 3 Click on the Setup tab at the top and then click on Wireless Settings on the lefthand side.
Step 4 From the Wireless Security Mode dropdown menu, select WPA-Personal encryption.
Step 5 From the WPA Mode dropdown, Under WPA, select the form of WPA you would like to use.
Use WPA or WPA2 mode to achieve a balance of strong security and best compatibility. This mode uses WPA for legacy clients while maintaining higher security with stations that are WPA2 capable. Also the strongest cipher that the client supports will be used.
For best security, use WPA2 Only mode. This mode uses AES(CCMP) cipher and legacy stations are not allowed access with WPA security.
For maximum compatibility, use WPA Only. This mode uses TKIP cipher. Some gaming and legacy devices work only in this mode. To achieve better wireless performance use WPA2 Only security mode (or in other words AES cipher).
Step 6 In the Pre-Shared Key box, enter the desired Pre-shared key.
This is the "password" that allows communication between you're encrypted client (e.g. the PSP or your wireless computer) and the encrypted wireless signal coming from the router. This password must contain at least 8 characters, the characters can be anything you can create from your keyboard.
Step 7 Click on Save Settings
May 07, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
WPA code
The WPA code is part of the wireless configuration, it is the WPA encryption setting (WPA2 is the latest and strongest encryption version).
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (The Linksys configuration URL is http://192.168.1.1 )
The default login username is admin
The default password is admin
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Aug 18, 2010 | Linksys WRT160N Wireless Router
I hv a DIR-655 router & i've lost my manual. i want to secure my router and lock out others outside my residence. can you take me thru the steps?
Please visit http://support.dlink.com/faq/view.asp?prod_id=2484 for complete FAQ and screen shots.
Step 1
This is the “password” that allows communication between you’re encrypted client (e.g. the PSP or your wireless computer) and the encrypted wireless signal coming from the router. This password must contain at least 8 characters, the characters can be anything you can create from your keyboard.
Step 7 Click on Save Settings to save your settings.
thanks Ranjit
Dec 09, 2009 | Computers & Internet
Don't remember network key code to add to another computer
You need to reset your router to it's default settings and configure your network security again.
Nov 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I hope this helps.
Aug 18, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Securing wireless network
I have here the step by step guide from Belkin's Support site.
Configuring WPA-PSK Encryption:
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
  4. Click Security under Wireless menu.
  5. Under Security Mode, select WPA/WPA2-personal (PSK)
  6. Select WPA2-PSK as your Authentication
  7. Select AES as the Encryption Technique.
  8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  9. Click Apply changes to save the settings.
May 21, 2008 | Belkin Computers & Internet
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
222 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
